Fluid leak; air con compressor?
Old Mar 3, 2014 | 10:49 AM
211oakland's Avatar
211oakland
I've got a 2001 E250 gas van. I noticed a fluid in the passenger wheel well, apparently leaking thru from engine bay via what probably is a cable- holder on the other side. There was fluid on top of the battery, and on the fitting aft of it, and on the flex conduit of the positive battery cable. But one elsewhere icould see. Fluid seems to be greenish, and slick like hydraulic fluid but not oil. Repels water.
I suspect air con; getting a bit of a rotational noise and it seems to change when I flick on air con. But I'm off-roading and bels often get dusty and a bit noisier. Air con still works though .
Is it the compressor? How much a prob to fix? I'm just at 90k miles.
Thanks, Rob
Old Mar 6, 2014 | 03:55 PM
thewestie's Avatar
thewestie
Sure its not antifreeze leaking from the heater core?
Old Mar 6, 2014 | 06:35 PM
211oakland's Avatar
211oakland
I don't think it's antifreeze, since it repels water like oil. But then again maybe all I'm seeing is residue after it evaporated. Still....
Having somebody with more brains than me check it out. In 500 miles of driving a couple of days ago couldn't replicate it.
Be hilarious if it turns out I just left something sitting in there that melted.
Old Mar 7, 2014 | 04:21 PM
tabijan's Avatar
tabijan
At the point oil leaks out of the AC system, I doubt there'd be enough refrigerant to overcome the low pressure switch. Basically, the compressor wouldn't engage. Is your coolant green?
Sixto
93 E150 Chateau 5.8 187K miles
Old Mar 7, 2014 | 04:57 PM
211oakland's Avatar
211oakland
Yes, lime green.
Rob
One Sock
Jul 3, 2012 05:44 PM
Bruker
General Automotive Discussion
Jun 11, 2007 09:38 AM
sparksalot
Apr 18, 2007 09:14 PM
dumdum9599
13
Nov 17, 2006 03:35 PM
