Idle speed
Old Mar 3, 2014 | 09:01 AM
tbugher62's Avatar
tbugher62
Idle speed
Hi Guys,Do you know about what my 94 f 350 460 cid engine is suppose to idle at,its about 900 right now give or take a few.If thats too high or low what do you think is wrong,the truck idles smooth with no problems.
Old Mar 3, 2014 | 09:38 AM
Conanski's Avatar
Conanski
Idle speed should be about 650-700rpm so it appears you are a little high but your tach could also be off, maybe verify idles speed with a hand held multimeter or scope. Idle speed is computer controlled so if it's not right it's usually because of a sensor problem, pull codes to see if anything is flagged and if that's all clear(code 111) back probe the TPS sensor so see if it's within spec.
Old Mar 3, 2014 | 10:25 AM
powerstroker100's Avatar
powerstroker100
Subscribing
Old Mar 3, 2014 | 03:18 PM
tbugher62's Avatar
tbugher62
Sorry but what is the TPS sensor
Old Mar 3, 2014 | 04:28 PM
powerstroker100
throttle position sensor, it will be on the driver side of the cobra head with a 3 wire pigtail, back probe it to see what voltage is at idle and wide open throttle, sweep the throttle slow and make sure the voltage change is consistant and there are no dead spots, you can back probe another one of the wires to make sure it is getting 5v
should be between .6-1v at idle
Old Mar 5, 2014 | 09:22 PM
PRIMERED79 SHORT BED's Avatar
How does one use a multimeter to check rpm?
Jrock909
Apr 29, 2007 01:06 AM
celticrebel
1978 - 1996 Big Bronco
Mar 18, 2004 10:49 AM
travisca
1983 - 2012 Ranger & B-Series
Jul 26, 2003 04:19 AM
tmcalavy
May 4, 2001 05:12 PM
fairlaniac
Sep 15, 2000 10:38 PM
