idle speed
Old Jul 10, 2003 | 01:45 PM
travisca's Avatar
travisca
idle speed
At stops, my engine does not want to return to idle quickly (800 rpm).. Any suggestions? Thanks.....
Old Jul 11, 2003 | 06:41 AM
Rockledge's Avatar
Rockledge
idle speed
Have you tried cleaning your IAC?
Old Jul 11, 2003 | 06:46 AM
Bob Ayers's Avatar
Bob Ayers
idle speed
It could be your TPS (Throttle Position Sensor) also......
Old Jul 13, 2003 | 01:13 AM
ludis's Avatar
ludis
idle speed
It could also be programmed to have a brief high idle.
Old Jul 13, 2003 | 02:50 PM
wptski's Avatar
wptski
idle speed
travisca:
It's not supposed to drop to idle too quick, that's a anti-dashpot function of the IAC but it maybe be commanded by the PCM. Like someone suggested, clean your IAC and it wouldn't hurt to clean your throttle body too.
Old Jul 14, 2003 | 11:15 AM
travisca's Avatar
travisca
idle speed
What and where is IAC and a throttle position sensor??? Can the average "joe" clean, check and repair these problems?... If so, what do I do??? Thanks guys for the prompt reply???
Old Jul 14, 2003 | 12:29 PM
Rockledge's Avatar
Rockledge
Question idle speed
What and where is IAC...
Your Idle Air Control Valve (IAC) allows a certain amount of air to bypass the closed throttle position in order to maintain proper idle speed. It is controlled by the PCM.
Read more on it here: Idle Air Control Valve
Old Jul 14, 2003 | 12:44 PM
travisca's Avatar
travisca
idle speed
Ok, so if I understand this, the IAC can make the idle remain high while at a stop... Most of the compliants where nosie... How do I check the IAC??? Thanks
Old Jul 14, 2003 | 12:47 PM
travisca's Avatar
travisca
idle speed
Bill, thanks, how do I clean the IAC and throttle body??? I appreciate ALL of the replies.... ..
Old Jul 14, 2003 | 05:27 PM
Rockledge's Avatar
Rockledge
idle speed
You should pick up a Haynes Repair Manual for your truck, they come in handy for many small repairs and general maintenance.
You can get an idea about cleaning your throttle body by reading here: Cleaning Your Throttle Body
You clean your IAC by taking it off and spraying it with Throttle Body Cleaner, maybe get a can of compressed air to help blow out the crud.
You can check your TPS using these instructions: Throttle Position Sensor (TPS) Testing
Here is a picture of the TPS and IAC on a 4.0L:
Old Jul 14, 2003 | 09:21 PM
wptski's Avatar
wptski
idle speed
We can post pictures here now? Or was it always like that but I never could figure out how to do it?
Old Jul 26, 2003 | 04:19 AM
FyreLyter's Avatar
FyreLyter
idle speed
man I learn something new everyday!!!
pbarw
1978 - 1996 Big Bronco
Aug 5, 2014 01:59 PM
B1GKAHUNA
Apr 9, 2014 09:18 AM
Al T
Apr 8, 2014 07:28 PM
Gerryatrics
1997 - 2003 F150
19
Mar 30, 2014 06:11 PM
kenmt
15
Mar 13, 2002 01:52 PM
