broke down 96
Old Apr 7, 2014 | 10:17 AM
  #76
dazedandconfused's Avatar
dazedandconfused
This thing is almost 2 inches wider then my spring.
Old Apr 7, 2014 | 10:22 AM
  #77
DIYMechanic's Avatar
DIYMechanic
Is this a cab and chassis truck or a pickup? Mine was off by maybe 1/4" but definitely not 2".
Old Apr 7, 2014 | 11:44 AM
  #78
dazedandconfused
Cab and chassis truck.
Old Apr 7, 2014 | 12:42 PM
  #79
farmert's Avatar
farmert
This is your problem. You have the hanger for a pickup, the cab and chasis use 2 1/4" springs, the pickup us the wide springs.
Old Apr 7, 2014 | 01:25 PM
  #80
DIYMechanic
Yep. I can't believe I missed that one earlier on. IIRC if you look at the title or registration of your truck there it will list the model as a F-59? Does that sound right? If that's the case then you need this part instead:
More Information for SHERMAN 57582H
Rock sells them for about $34 each and they're a non-stock item so they'll take a little longer to get there.
That's my bad. For whatever role I played in getting you the wrong parts, I apologize. I didn't realize it was a C&C and not a pickup.
Old Apr 7, 2014 | 01:33 PM
  #81
dazedandconfused
The hanger was the same as the other side other then one hole being off its the shackle that's different. I called my spring shop and he said all of the spring packs are the same width so I don't know what the deal is. I double checked with him before ordering the part and he told me it was the one I needed. I have no tag on my cabs door opening either.
Old Apr 7, 2014 | 01:35 PM
  #82
DIYMechanic
Is it titled and registered as a truck or as an F59?
There is definitely a difference in the springs between a truck and a cab and chassis because of the narrower frame and axle perches.
Old Apr 7, 2014 | 01:48 PM
  #83
dazedandconfused
Its a cab and chassis truck. Its a 10' dump but I don't recall ever seeing F59 on anything.
Old Apr 7, 2014 | 04:52 PM
  #84
dazedandconfused
The title has it listed as a F350 I just looked. Here are a couple pics I shot of the differences.
Old Apr 7, 2014 | 08:48 PM
  #85
DIYMechanic
How wide are your springs if you measure them?
Old Apr 8, 2014 | 03:59 AM
  #86
dazedandconfused
Two and a half inches at the bushing roughly. There is an inch gap you see in that pic.
Old Apr 8, 2014 | 06:24 AM
  #87
DIYMechanic
Pickup springs are 3" wide. You have cab and chassis truck there and it requires different hangers and shackles than a pickup. I wouldn't be surprised if there was nearly a half inch of space in mine before I cinched the bolts down and drew it together, so that likely accounts for the additional space you're seeing.
Old Apr 8, 2014 | 07:40 AM
  #88
dazedandconfused
Well looks like I'll be returning these and just going to the junk yard this week.
Old Apr 8, 2014 | 09:13 AM
  #89
farmert's Avatar
farmert
Try these guys, I have had good luck with them. This is the shackle for the cab and chasis 1980-1997 Ford F350 (2 1/4 Springs) - Rear of Rear Shackle - 330-171 | $28.95 . If you scroll down you will see the replacement hanger.
Old Apr 8, 2014 | 10:12 AM
  #90
dazedandconfused
This will work won't it?
1992-1998 Ford F350 Cab & Chassis - Hanger & Shackle Kit (2 1/4 Springs) [One Side] - M98330 | $56.95
