Driver's side oil leak
Old Mar 2, 2014 | 08:23 PM
Michael Hoersten's Avatar
Michael Hoersten
So I have noticed that my truck has been putting a few drops of oil on the ground when its idling and can smell oil burning occasionally. I changed the valve cover gaskets and after looking on the forums, I checked to see if I over tightened them and everything is dry above the exhaust manifold. But when you look underneath the exhaust manifold everything is basically caked in oil. But it drips down onto the front axle.
Could this be a head gasket?
I checked the oil filter and its tight but it has oil streaks on it from above it.
I read somewhere that it could be the turbo drainback line.
Forgot to mention the specs:
1993 F250 IDI factory turbo, 5 speed, 4x4, 290,000.
New IP, injectors, valve cover gaskets
Old Mar 3, 2014 | 05:57 PM
Michael Hoersten
bump, hope someone can give me some pointers.
Old Mar 3, 2014 | 07:52 PM
fordtruckman838's Avatar
fordtruckman838
It sounds like it may be the oil cooler leaking. There are some o rings where it bolts up to the block and it sounds like one of them may have failed in this case. The oil cooler is the part that the oil filter threads onto.
A head gasket should not cause an oil leak and if it were leaking your engine would be missing pretty bad.
dmanshane
Dec 1, 2013 07:30 PM
Mattruck1992
Nov 20, 2011 09:07 PM
levimorris85
Jun 8, 2011 08:13 AM
91gettaDI
Jan 8, 2010 09:51 PM
Ritechous_23
Feb 17, 2009 06:43 PM
