steering colum swap
Old Mar 2, 2014 | 01:59 PM
bigblock460ford's Avatar
bigblock460ford
steering colum swap
Cant find good steering colum for my 1979 f250. Has anyone swaped one with later year truck. whats involved in doing it.
Old Mar 2, 2014 | 02:17 PM
wyckedcombo17's Avatar
wyckedcombo17
Can't find a good column as in the u joint/rag joint is shot? You might wanna look at just replacing the shaft
Old Mar 2, 2014 | 10:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bigblock460ford
Can't find good steering columN for my 1979 F250. Has anyone swaped one with later year truck.
1978/79 F100/350 is the same, 1980 and later will not work!
But, there are differences between these 1978/79 columns: 2WD or 4WD? A/T or M/T? With or without a tilt steering column?
Which part(s) are defective?
Old Mar 2, 2014 | 10:38 PM
84espy's Avatar
84espy
How urgent is this and where are you located? I will be swapping out my column in two weeks. The only things wrong are that the shift indicator is broken and shifter connection is partially busted, It works though and parts inside can be used to make yours whole. It came off a 79. It will be free plus shipping if you are interested.
Old Mar 3, 2014 | 07:17 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
73-mid 77 (I believe) has a different main electrical plug for turning signals ect...and safety neutral switch is on the column (for an auto trans).
77.5 to 79, safety neutral is on the transmission, for an automatic transmission truck.
Might be ahead to just get the parts to repair yours....
Old Mar 3, 2014 | 09:56 AM
NumberDummy
1967/77: NSS located on the column, same for all A/T's / 1978/79: NSS located on trans, C4 uses a different NSS than C6.
77.5 (not FoMoCo terminology) only pertains to F250 4WD's, as the last Highboy (not FoMoCo terminology) was assembled mid-model year 1977 that occurred in February.
1973/77 T/S switches different than 1978/79.
rsirrin
May 15, 2015 02:42 PM
DeanBob
Jan 10, 2014 03:13 AM
SuperDuty93
13
Jul 13, 2012 08:33 PM
wlittle
Jan 14, 2012 12:56 AM
77460ford
Sep 26, 2006 09:23 PM
