Steering setup
Old Apr 13, 2017 | 09:24 PM
jswartz84's Avatar
jswartz84
Steering setup
I'm having a minor bump steer issue. I've searched through some threads trying to find a solution but haven't found anything as of yet.
I swapped from the inverted y setup to the t style on my 77 F150 so tie rod ends are new and tight. All of the bushings in the front end are new and it has a 3.5" lift installed. The Trac bar and the drag link are very close to parallel. Could it possibly need a new steering stabilizer or do I need a drop pitman arm and trac bar drop bracket?
Here is a picture, what do you guys think?
Old Apr 13, 2017 | 10:21 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I'm not really a a 1/2 ton guy, but with a 3.5 lift I bet YES on the drop pitman arm and trac bar drop bracket.
Having the the trac bar and the drag link are very close to parallel is on the right track.
Old Apr 14, 2017 | 12:34 AM
HIO Silver's Avatar
HIO Silver
Concur with Rich...
Dropped pitman arms are widely available. I got a Skyjacker arm.
I went with a BDS track bar drop bracket... well made and fit nicely.
MattMac
Oct 20, 2017 03:10 PM
66shadow
Apr 13, 2013 11:37 AM
kbrenner536
Aug 20, 2011 09:19 AM
quaallen
Offroad & 4x4
13
Mar 11, 2011 11:55 PM
Ford79
Sep 4, 2002 03:10 PM
