Hey guys my van stopped firing. I tried all the suggestions. No luck.
I tried dissconnecting the ecu and turned theengine over and it started to fire.
Does this mean the ecu is fried. It didn't start . That must be because the ecu controls and fuel pump.
hi cant see the replies to this
so sorry if I am duplicating something
I had a similar problem and it was the capacitors in the ecu (big problem on 1994/5 ecu) they fail over time and they are part of the injector control they are the blue ones on the board and really easy to change if you can use a soldering iron
