Mine shows what ever number of DTC's are in the system. I have then scanned with Torque APP and it shows which ones they are. So, for me, I think the DTC SGII Xgauge works.
Its almost lime its stuck in od. Kinda like a car does when the torque converter is locked up all the time. Ever hear of a torqshift being stuck in overdrive?.
You need to be able to read extended codes with a proper IDS. I wonder if you have tranny codes.? It's strange that you are not getting a cel or a flashing tow haul light or something if it's the tranny. Well, it's also strange your not getting a cel for engine codes of some type.
I know. When its in drive and doesnt die i can watch the ipr and icp rise on their own, and it smokes grey. When it goes into gear and doesnt act up the icp stays at 581-585 and the ipr is at 23-27%, with no smoke. Once i bet a scanner ill post what i find. Weird though first thing this morning how it died instantly when i put it in any gear. And wben it died it was because of excessive load, not just dying so to speak.
No long cranks, it fires right up like normal. No cat. Went out and fired it up and itll go into gear and run. I can hear it surging a little. Icp at 588, ipr at 23%. When i go to give it throttle in gear itll start to rev, but then just falls on its face at about 1/4 throttle, and i can take it to the floor with no difference at all. Highest it revs is 1100 in gear under load. Tried disconnecting the icp but didnt change a thing. In park its responsive as can be. I did notice this morning that it would shift into and out of drive quite a bit by itself. Lime i have a bad lo-reverse solenoid. Still no cel, or no tow/haul light on.
After reprogramming the xgauge it does show 1 code. Hpefully itll give me a starting point. Thanks alot for all the xgauge numbers.
