Need a little guidance
Hey fellas!
Ok there is my problem. It's a 2002 Excursion 7.3l. I have this hum I want o say at idle. I can feel it in the steering wheel and brakes pedal. It goes away when I give the truck a little gas (basically raise the RPM). The hum I'm 90% sure is from the front but you can hear it resonate to the back.
Here is what I've done so far to tackle the problem:
1. checked to make sure nothing was touching anywhere to perhaps cause it to hum like that
2. Power steering fluid flush
3. Changed Harmonic balancer (while in there changed out tensioner and slapped on a new belt)
Noise is still there. I've researched a little and am led to believe it might be the hydro boost or the power steering pump. I don't want to throw parts at it without some kind of diagnosis.
This is my first diesel truck so I'm learning as I go.
Any help would be great guys! I wanna get this truck in perfect shape for the summer!
Thanks in advance for any guidance.
I will have to check that. Today I noticed while driving the noise wasn't as bad. I think the colder it is, the worse it is. The noise started up after the truck warmed up (driving).
I looked at the exhaust, and it appears at the end of the exhuast pipe it is a little loose back there. The busing on the hanger doesn't seem to be holding it rock solid in place. I'm wondering if that would case enough of a resonance in the truck.
Just to add to the "symptoms".....
When you first start the truck none of that noise is there. It only seems to start happening after you start driving it for a bit. Then the hum starts.
Somedays its a little more obvious then others. I'm really leaning towards something on the exhaust somewhere.
Another clue. When the truck is at standard idle, the noise is not there. When the truck sits at park for a bit and the idle goes up the noise goes away.
When I am driving the truck, the noise is never there. Only at low speeds and idle. I'm really wondering if this is the steering pump or the Hydroboost. Brakes are fine, steering is fine. I did use the Mercon P/S fluid.
The mystery continues.
Hey everyone! Just dropping a line to let you guys I still haven't figured this one out yet. I haven't had time to try taking the belt off and seeing if the noise was still present.
I keep wondering if this is an exhaust issue. If I am at idle the hum is there, the second I give it a little gas the noise is instantly gone.
Hope to get to this soon!
Garrett Killgore
09-17-2016 07:34 AM
F250W6.0
01-28-2012 09:05 AM
