Virginia Chapter Join Chapter, Leader:
VA's March'n BS Thread
Old Mar 22, 2014 | 10:47 PM
  #946
Sparky83's Avatar
Sparky83
did you find enough yet??
Old Mar 22, 2014 | 11:24 PM
  #947
archtaan's Avatar
archtaan
Never enough Shawn! What did you do today?
Old Mar 22, 2014 | 11:41 PM
  #948
Sparky83's Avatar
Sparky83
Spent the day cussing at the 350 and the parents...
Old Mar 22, 2014 | 11:46 PM
  #949
archtaan's Avatar
archtaan
Uh oh. What happened?
Old Mar 23, 2014 | 12:02 AM
  #950
Sparky83's Avatar
Sparky83
350 - the prndlll been little loose.. So took the dash apart to investigate.. Apparetly the plastic bushing are worn out.. Which is what's letting the lever move.. While I had the dash out I decided to investigate the power port again.. Before when I tried to troubleshoot it not working it suddenly started working again... Got in the truck the next day nothing.. Neghibors trucks doing the same.. I just decided F* it.. And replaced it with a universal.. Downside is ford used a plastic plug to hold it in place so what should have been a 7/8" hole.. Was made into a hole bigger than 1". Had to find some washers to fix that issue... Then discovered my female blade connectors walked off somewhere again...
Whole time I was dealing with that.. The parents decided to mess withthe truck.. "Trying to be helpful" they refilled my washer fluid tank.. I've been trying to clear that tank out for the last couple months cuz I didn't like what the shop filled it with. That craps been nothing but problems.. I had the tank almost to half when they refilled it.. Now that craps been remixed and gonna take forever to empty again..
Old Mar 23, 2014 | 12:06 AM
  #951
Sparky83's Avatar
Sparky83
problem with the crap thats in that tank is its more of a soap mix than actual window cleaner.. so all it does is smears whatevers on the window.. and on top of that anytime it gets remotely near 32 it freezes the system completely... and whats worse is it doesnt dilute either.. once i got it emptied id planned to take the tank off and thoroughly clean it out and also replace the tubing as well... but now it gotta wait again..
Old Mar 23, 2014 | 12:19 AM
  #952
Sparky83's Avatar
Sparky83
did find wires in my truck... decided to follow them to see where they went.. found this mess under the carpet.. Im gonna rip out next time i have the dash apart..
and since i had the dash apart anyways... i test fitted my fun gauge pod to see how itd fit.. found out itll be alot easier to mount with the time comes...
Old Mar 23, 2014 | 12:31 AM
  #953
archtaan's Avatar
archtaan
Looks like it was a busy day. That silver plug looks like it went into either a cb or a radio.
i am picky about my windshield fluid. I hate smears on the window when i drive.
Old Mar 23, 2014 | 12:38 AM
  #954
Sparky83's Avatar
Sparky83
plug for satellite radio... the lil antenna box is still on the roof.. now that i know for sure the box isnt in the truck im gonna rip em out..
i am too.. im tired of the nozzles freezing up when i need em.. and the crap smearing the window... thats why i was trying to use it up so i could clean it out and refill it with stuff i know works right...
Old Mar 23, 2014 | 12:41 AM
  #955
archtaan's Avatar
archtaan
Couldn't you just hold it down and run through it all?
That Guage pod looks good too. Very unobtrusive.
Old Mar 23, 2014 | 12:46 AM
  #956
Sparky83's Avatar
Sparky83
wanted to actually use it with a purpose.. i could suck it outta the tank and just dump it but didnt want to waste it like that.. problem has been every time i NEEDED it is when the thing froze up...
thats where the fun ones going to go
Old Mar 23, 2014 | 12:52 AM
  #957
archtaan's Avatar
archtaan
Well hopefully the weather will warm up and you will use it through the spring and summer.
Catch ya later. I'm falling asleep.
Old Mar 23, 2014 | 01:00 AM
  #958
Sparky83's Avatar
Sparky83
night tim...
Old Mar 23, 2014 | 08:12 AM
  #959
GLR's Avatar
GLR
Morning all. Darn white stuff coming down up here.
Old Mar 23, 2014 | 07:29 PM
  #960
archtaan's Avatar
archtaan
Evening peeps.
