Windsheild washer sprayers
Old Feb 27, 2014 | 08:46 PM
Mustangking1's Avatar
Mustangking1
My sprayers for the windsheild washer fluid are clogged or something so they will not spray.... Anyone know where to buy new ones or fix my current ones?
Old Feb 27, 2014 | 08:52 PM
spikinfool05's Avatar
spikinfool05
soakem in brake clean. then blastem with the air gun.
Old Feb 27, 2014 | 08:53 PM
HIO Silver's Avatar
HIO Silver
Pull 'em and use compressed air to clear the passages. Insert your air gun in the outlets or the "reverse" direction. It's usually a piece of trash lodged in there.
Still kaput? Soak 'em in CLR or Lime-Away to dissolve the calcium build up. Sometimes it's actually the windshield washer colorant that gets builds up in the passages. Regardless, the CLR or Lime-Away will prolly clear 'em. Again, compressed air to blow 'em clean.
Good luck.
Old Feb 27, 2014 | 09:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
People pore tap water instead of distilled water into the washer reservoir, calcium buildup begins.
Polish/wax can also clog up the sprayers (washer jets). White vinegar will also clean 'em out.
Also...check the rubber hoses for cracks where they attach to the reservoir, jets and washer T (17A601).
D3TZ-17603-A .. Washer Jet-Right/Left same / Obsolete
Applications: 1973/79 F100/350 & 1978/79 Bronco.
NOS PARTS LTD in Waxahachie TX has 2 = 972-937-2201.
PARTS INTERNATIONAL in Farmers Branch TX has 3 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
Old Feb 27, 2014 | 10:53 PM
Mustangking1
Thanks Guys!
I will pull them tmrw and soak them in some white vinegar first.
Hopefully that fixes it but if not i will move onto the brake cleaner.
I have already found that the nozzles are clogged since there are no leaks else where.
Old Feb 28, 2014 | 05:34 PM
brokersteve's Avatar
brokersteve
My passenger side was clogged recently. I pulled the sprayer and operated it to make sure it came out of the hose. I used a fine wire from a wire brush and dislodged what was in there. Reinstalled and it works fine now.
Old Feb 28, 2014 | 08:41 PM
Blue and White's Avatar
Blue and White
Fine wire did it for my pass side also. I believe it was clogged with the blue colorant as posted above.
grayf250
Mar 13, 2015 03:26 PM
shockr4
2004 - 2008 F150
Jul 2, 2014 04:31 PM
nooon
Jan 8, 2005 07:30 AM
Soljah
1983 - 2012 Ranger & B-Series
Nov 18, 2003 08:59 AM
SecondBass
Appearance & Dress-Up
43
Jun 12, 2003 03:27 PM
