Front Spring Shackles
Old Feb 27, 2014 | 07:49 AM
Branded's Avatar
Branded
How tight should I tighten the front spring shackles,will they bind if over tighten. I'm thinking with the fitted sleeve on the pins that one wouldn't be able to vertigo ten and cause a binding issue. Am I thinking correctly.
Old Feb 27, 2014 | 10:23 AM
raytasch's Avatar
raytasch
Believe Nothing
Last vehicle I did, it was 35 ft lbs and back off to the previous pin, castle nut alignment. You're thinking right, too tight and it could bind. We don't know what you're working with.
Old Feb 27, 2014 | 11:01 AM
Branded's Avatar
Branded
Thanks ..... Sorry 54 F100
jbontke
Jun 11, 2015 10:26 AM
Major Marvin
Sep 3, 2011 10:40 PM
Pollack Pete
Feb 24, 2011 05:14 AM
Jens
Florida Chapter
Dec 8, 2004 11:59 AM
