Coolant change ?
Old Mar 4, 2014 | 07:47 AM
9228.bobcat's Avatar
9228.bobcat
Originally Posted by Monty Simmons
Is it ok to simply put the end of a water hose in the degas bottle and take of the bottom radiator hose off and drain the radiator while water hose inputs tap water into degas bottle while the engine is idling?
I wouldnt put tap water in there for starters and secondly if you put cold water in a hot engine your going to blow your egr/oil cooler or crack your heads.
Old Mar 4, 2014 | 08:23 AM
Monty Simmons's Avatar
Monty Simmons
So I guess one heats any fluid before pouring same into degas bottle, right?
Old Mar 4, 2014 | 08:26 AM
9228.bobcat
So I guess on heats any fluid before pouring same into degas bottle, right?
If the engine is hot and the coolant level is very low, I do. If the level in the degas bottle is somewhat close to minimum then I dont worry about it.
Mikenski
Oct 13, 2015 04:41 PM
osteo16
Jan 6, 2014 07:51 AM
97XLT4X4
Mar 29, 2011 04:30 PM
lucaslaw
Aug 11, 2009 08:59 AM
skilife17
1997 - 2003 F150
Nov 20, 2006 11:49 PM
