Coolant change ?
Old Feb 26, 2014 | 04:46 PM
Iaff113's Avatar
Iaff113
Coolant change ?
Hello all. Ok so deltas are great within 3 I was just thinking about a drain and fill, can I get away with just pulling the lower hose and draining? And then refilling with 50/50 gold. Or are their more point I will have to drain from? I just read through 36 pages of posts and didn't find a defining answer. Thanks
Old Feb 26, 2014 | 05:31 PM
9228.bobcat's Avatar
9228.bobcat
Did you have ford gold in it to begin with?
Old Feb 26, 2014 | 05:35 PM
Iaff113's Avatar
Iaff113
Yeah it has had it in it since i got it
Old Feb 26, 2014 | 05:39 PM
9228.bobcat
I would pull lower radiator hose drane. Fill back up with distilled water, run it for 20 or so minutes.let cool, drane again and fill up with straight gold.not 50/50. Then your done.
Old Feb 26, 2014 | 05:42 PM
Iaff113's Avatar
Iaff113
Straight gold. are you talking about making it he mixture yourself? Or straight no 50/50 mix
Old Feb 26, 2014 | 05:47 PM
69cj's Avatar
69cj
Not a good idea. After your second or third drain refill with 1/2 the full capacity with straight Ford Gold and then top off with distilled water. You want a 50/50 mix.
Old Feb 26, 2014 | 05:52 PM
Iaff113's Avatar
Iaff113
Yeah I'm not doing a flush here I just want to do a drain and fill. I have no reason to do a flush So I can just drain and fill up with 4 gal or so of the ford 50/50 mix
Old Feb 26, 2014 | 05:56 PM
npccpartsman's Avatar
npccpartsman
Just draining will only remove 1/2 the system capacity that's why Eric and Mike said use distilled water for a "flush". You want to get all the old coolant out. Draining once and filling once with distilled water really won't get all the old out, that's why Mike suggested 2 or 3 "flushes" with distilled. After you drop the last flush you can refill with 3.5 gallons of straight and top off with distilled to have a 50/50 mix.
Old Feb 26, 2014 | 06:00 PM
Iaff113's Avatar
Iaff113
Ok that clears it up. Thanks for the info
Old Feb 26, 2014 | 06:03 PM
Iaff113's Avatar
Iaff113
One more stupid question. When filling can you just fill through the degas bottle or rad cap
Old Feb 26, 2014 | 06:14 PM
69cj's Avatar
69cj
Yes you can. Fill to the min line and drive to temp. Let it cool over night and then fill again with 50/50 to the min line. May take 1 or 2 times to get all of the air out of the system.
Old Mar 3, 2014 | 07:08 PM
Iaff113's Avatar
Iaff113
If I just did drop the lower hose one time and drained. Would the 3.5 of straight gold and top off with distilled water still apply or is that only when you have the system full of distilled water from multiple drops
Old Mar 4, 2014 | 04:31 AM
npccpartsman
If you just drop the lower hose one time the rest of the system still has 3.5 gallons of old coolant in it. At that point you'd use 50/50 to top it off.
The reason you fill the system with water multiple times is to get all the old coolant out. I usually flush with clean tap water a couple of times then two or three times with distilled. After the last hose drop I refill the system with 3.5 gallons of straight coolant and finish with distilled.
I also remove the thermostat so the liquid goes through the whole system faster. You can do multiple flushes in an hour vs. waiting for the vehicle to have to warm up.
Old Mar 4, 2014 | 06:34 AM
bismic's Avatar
bismic
After you are done, you will have air in the system. You will need to vent the degas bottle (VERY carefully and slowly remove the cap when it is under pressure) a few times to work the air out of it.
Old Mar 4, 2014 | 06:53 AM
Monty Simmons's Avatar
Monty Simmons
Is it ok to simply put the end of a water hose in the degas bottle and take of the bottom radiator hose off and drain the radiator while water hose inputs tap water into degas bottle while the engine is idling?
