E550 electrical problems
Old Feb 26, 2014 | 01:45 PM
flyboys101's Avatar
flyboys101
Hello, my E550 van front/box back has an electrical problem.
Sometimes when I first start it and step on the brake my backup beeper warning goes on. Most times it stops once I start driving, but sometimes it continues for a while or comebacks back by chance. Doesn't matter where the shifter lever is, park, reverse or drive.
Yesterday it woke up really bad and anytime I used a turn signal or flasher I got a fast blinker and beeper going. Figured I had a light bulb out. Looked around the truck and noticed no taillights. Shut truck off went inside a building with flashers on, beeper was going. When I restarted, beeper stopped and I had right side taillights but no left Drivers side.
Drove back home still no left side.
Have no idea where to start looking. Electrical is not my strong suit.
Any and all help appreciated.
Old Mar 1, 2014 | 05:25 AM
JWA's Avatar
JWA
Assuming the back up beeper is an aftermarket part I'd say its receiving stray signals from who knows where. Its possible there is a loose wire or failed connection allowing the intermittent and unpredictable alarm operation.
Whatever switch engages the alarm needs to be carefully inspected, connections tested for being tight on their terminals. This might reveal something easily fixed.
Since this is most likely not factory installed the alarm's manufacturer would need to be contacted for the appropriate hook up schematic. This sort of info wouldn't be part of an EVTM's included schematics.
Not too helpful I know but some of these things don't lend themselves to easy diagnosis, especially on a forum.
Old Mar 1, 2014 | 03:06 PM
moosey78's Avatar
moosey78
I have an aftermarket reverse beeper on my van. It's probably not the same as your or even wired the same way. But mine was tied in to the reverse light positive wire on the passenger side.
gj020
2004 - 2008 F150
Jun 4, 2019 04:20 PM
ianobetz
Feb 27, 2016 03:37 PM
flyboys101
Electrical Systems/Wiring
Mar 11, 2014 11:31 AM
flyboys101
Feb 27, 2014 07:56 AM
stroken
Jul 25, 2007 11:20 PM
