Sponsored by: Real Truck
E550 electrical problems
Old Feb 26, 2014 | 02:02 PM
flyboys101's Avatar
flyboys101
Hello, my E550 van front/box back has an electrical problem.
Sometimes when I first start it and step on the brake my backup beeper warning goes on. Most times it stops once I start driving, but sometimes it continues for a while or comebacks back by chance. Doesn't matter where the shifter lever is, park, reverse or drive.
Yesterday it woke up really bad and anytime I used a turn signal or flasher I got a fast blinker and beeper going. Figured I had a light bulb out. Looked around the truck and noticed no taillights. Shut truck off went inside a building with flashers on, beeper was going. When I restarted, beeper stopped and I had right side taillights but no left Drivers side.
Drove back home still no left side.
Have no idea where to start looking. Electrical is not my strong suit.
Any and all help appreciated.
Old Feb 26, 2014 | 07:00 PM
redford's Avatar
redford
FTE Leadership Emeritus
My first thought would be to check your grounds on that left side.
Old Feb 26, 2014 | 07:10 PM
craftsmangary's Avatar
craftsmangary
You've got a feed back issue because of a bad ground, there should be a ground wire connected to the rear of the left frame rail, it's probably corroded.
Old Feb 26, 2014 | 08:41 PM
flyboys101's Avatar
flyboys101
will check
Thanks will check that. Seriously thanks.
Old Feb 26, 2014 | 08:44 PM
flyboys101's Avatar
flyboys101
Figure Id throw this out there too. Since I will be looking around the rear tail lights, my tail lights are really low, under the lift gate. I was hoping to add more lights high up on the box frame. Found some nice long led lites that fit well. Which wires (color) on the brake lites coming out of the lite boxes would I tie into for brake, turn and nite lighting?
Old Feb 27, 2014 | 05:45 AM
redford's Avatar
redford
I strongly recommend that you fix your current electrical issue before you start adding more lights.
Old Feb 27, 2014 | 07:56 AM
flyboys101's Avatar
flyboys101
Oh absolutely, wouldn't dive into anything else before its fixed.
Just figured I have some people on here who know what their are talking about and would pick their brains while they were still looking at my post.
Mac92
Dec 5, 2017 11:59 PM
FoMoCo13
Jul 4, 2016 07:48 AM
flyboys101
Electrical Systems/Wiring
Mar 11, 2014 11:31 AM
flyboys101
Mar 1, 2014 03:06 PM
timeline
Oct 13, 2004 09:30 PM
