left reverse light isn't working....
Old Jul 22, 2007 | 08:19 PM
stroken's Avatar
stroken
my left reverse light doesn;t work...not a bulb..when you hit the back of the bed it comes on..well it use to now i can;t get it to come on at all, i was told ford has a problem with that but i don;t beleive it..if they can build a full truck how can they not get one reverse light to work? and the running lights and brake lights and turn signals work fine...sound like a wiring problem? any help would be great..thanks yall!
Old Jul 22, 2007 | 08:20 PM
Badluck's Avatar
Badluck
sounds like a short in the wires back there
Old Jul 25, 2007 | 08:24 PM
JIM ROLAND's Avatar
JIM ROLAND
HAD THE SAME PROBLEM WITH MINE YESTERDAY. THE BULB LOOKED PERFECT! PUT A TEST LIGHT TO THE HOT WIRE COMING INTO THE SOCKET AND IT LIT UP, SO I REMOVED THE BULB AND TEST THE CONTACT IN THE SOCKET, IT LIT UP TOO! PUT IN A NEW BULB AND PRESTO! I THINK THAT THE LEFT SIDE MIGHT NOT GET QUITE AS MUCH VOLTAGE OR SOMETHING AND MAY CAUSE THE CONTACTS TO OXIDIZE, JUST A GUESS. IF NEW BULB DOESN'T HELP TRY CLEANING THE CONTACTS IN THE SOCKET AND MAYBE PRYING THEM OUT A LITTLE TOWARD THE OPEN AREA WHERE THE BULB WILL GO, IT MIGHT HELP THE CONTACT. HOPE IT HELPS !
Old Jul 25, 2007 | 11:20 PM
stroken's Avatar
stroken
thanks alot jim...trucks in the shop because trans went out two days ago but as soon as i get it back i'll try it..thanks alot!
Daves94vert
Jan 5, 2013 10:26 PM
abyars111
Nov 12, 2012 09:18 AM
Pharticus
Jan 18, 2012 06:42 PM
wreckinball
Jun 1, 2010 02:32 PM
slinkeysghost
Electrical Systems/Wiring
Oct 25, 2005 12:39 PM
