sometimes the check engine light comes on and truck will not start,the fuel pump runs non-stop.. when check engine light goes off,the fuel pump runs for a few seconds and stops,truck will start.... driving down the road check engine light will come on and truck runs bad.... help!!!
Your 93 has OBD-1 diagnostics, so call ahead to determine if they can hook up to & pull codes from the Ford OBD-1 system.
You can pull the codes yourself, following instructions in the "Tech Info" thread atop this forums thread index page. Just scroll down to find "how to pull codes", or if you don't want to learn how to do that, maybe consider investing in an inexpensive OBD-1 code reader & it'll plug into your under hood diagnostic port & blink the code numbers, or give a numerical read out of the codes. Then post up All code Numbers, as they can provide good trouble shooting clues as ranger pat has suggested.
