1978 - 1996 Big Bronco
cam
Old Feb 26, 2014 | 10:43 AM
dalt582's Avatar
dalt582
cam
Guy this dude at work keeps talkin **** cause he has a 355 in a 80's gmc I have a 69 460 out of a lincon in my bronco its stock besides the 850 dub pumper an hedders an I don't have money to take it to get bored or aluminum stuff for the top end so I was gana port an polish my heads an I wana put the biggest cam an lifters thats compleatly over kill an un-called for in it what would the biggest size cam I can go with a stock set up
Old Feb 26, 2014 | 11:49 AM
gatorfor88's Avatar
gatorfor88
Idontknowdudeitsliketotrallyawesomeyouarewantingto showupsomeonesgmcwida355butmaybenexttimeyoupostath readyoucanyouknow
USE SOME FREAKIN PUNCTUATION.
Old Feb 26, 2014 | 12:23 PM
hivoltj's Avatar
hivoltj
NAWS Bro chacho
Old Feb 26, 2014 | 12:43 PM
Kemicalburns's Avatar
Kemicalburns
lots of factors to consider here. lumpy cams dont necessarily make power either.
that 850 seems to big as well. are you running the stock intake as well?
give us more info on your rig, tires, gears, trans, exhaust etc..
Old Feb 27, 2014 | 10:12 AM
hivoltj's Avatar
hivoltj
If you build engines like you type you're ****ed
Old Feb 27, 2014 | 11:25 AM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
An 850 double pumper on a 460?!? Unless you already have a lumpy cam and high numerical rear end gears that carb is not going to perform very well. Considering the rest of the engine is stock, I would suggest something like the Edlebrock Performer cam and carb setup.
Jim
Old Feb 27, 2014 | 03:11 PM
peganit2's Avatar
peganit2
LMAOwhathesaid
Old Feb 27, 2014 | 04:56 PM
Beechkid's Avatar
Beechkid
I would replace the 850 venturies with ones from the 1100 CFM and then get a cam with a 650+ lift and a 300+ duration....grin (joking)
for a few bucks you can install a 75hp nOX kit...........
Resurrected 56 F100
Jun 19, 2015 03:39 PM
carlmaass
May 24, 2011 11:00 PM
frankenford06
Mar 20, 2006 05:18 PM
icuhatn99
Jan 24, 2006 06:58 AM
DRanchero
Jul 21, 2003 12:02 AM
