stock heads
Old Mar 19, 2006 | 05:28 PM
frankenford06's Avatar
frankenford06
Talking stock heads
I've read allot of past post but I'm cofused on the valvetrain issue.What do you do when switching to a cam with more duration (more duration bigger cam) as far as adjustment goes. Do you have to switch to adj. rockers, mess around with adj. pushrods.Is there a cheap way of doing this? I'm not racing -it's just a toy , 1984 460
Old Mar 20, 2006 | 09:48 AM
Chiefrider007's Avatar
Chiefrider007
Lot's of considerations but, if you use hydraulic lifters/new cam all the stock parts should work just fine. I should say that's if you are at least moderate with the size of the cam.
Old Mar 20, 2006 | 04:11 PM
frankenford06
OK thanks.
Old Mar 20, 2006 | 05:13 PM
fordtruggy's Avatar
fordtruggy
Look in an aftermarket book with comp cams.The 270 cam is the bigges cam that can be run with stock valvetrain and no stall converter.It has a rough idle and builds power to like 6K.Its the lift that is hard on stuff and requires modifications not duration.
Old Mar 20, 2006 | 05:18 PM
frankenford06
well usually duration comes with lift, but this cam sounds ideal- just what I was looking for, thanks
