is it a good idea to just replace the screen or should I just replace the IPR?
how does the screen affect it so much? I am literally pushing less than 100 psi with Hpop. I would buy a failed IPR causing that but just the screen? thoughts?
If the screen was completely off then I would probably just get a new ipr. If the screen was just sucked in or junk on it I would replace the screen.
yeah I pulled out the screen before i put in the new IPR.. when I was cranking it was at 77.6 with the ICP plugged in and 55 something with the ICP unplugged
Here is a way of checking to see if you have sufficient high pressure oil without having a gauge or adapter. Strip back the wires about an inch away from the icp sensor connector. Obtain a digital multimeter and set it for voltage (DC). The bn-wh wire is a five volt reference, leave that alone. Strip back the db-lg signal wire and the gy-rd ground wire. Put positive lead on a dark blue-light green wire and negative lead on gray-red wire. Have an assistant crank truck, you need a minimum of 0.80 volts (500 psi) for the truck to start, if you are getting greater than that then you have sufficient high pressure oil. But it does sound like hpop.
