no start...
Old Feb 26, 2014 | 07:22 AM
Josh Baker's Avatar
Josh Baker
no start...
so after all that oil cooler work and stuff this weekend I woke up to a no start this morning...
It started up and ran but was surging this morning and then stalled and restarted with a long crank and now it won't turn back over. I noticed on that last start that I didn't hear my injectors clicking... I am leaning towards FICM or maybe since I just did all that work maybe a loose FICM connector? I did take the harness that connects the injectors to the FICM loose when I was putting in the oil cooler.
oil temp when I didn't hear the injectors was about 80 degrees.
~Josh
Old Feb 26, 2014 | 07:26 AM
9228.bobcat's Avatar
9228.bobcat
Yea I would check the ficm connectors. How long did you crank it? Can you hear your fuel pump kick on with key on?
Old Feb 26, 2014 | 07:30 AM
9228.bobcat
Are your batteries fully charged after all that cranking? I would throw a charger on them.
Josh Baker's Avatar
Josh Baker
yeah I can hear the fuel pump
Old Feb 26, 2014 | 07:32 AM
Josh Baker's Avatar
Josh Baker
already on it with the batteries.
Old Feb 26, 2014 | 07:34 AM
9228.bobcat
Check the connections on the ficm, put a charger on the batteries and keep cranking. See what happens. Sometimes it takes alot of cranking to fire it off. Dont burn the starter up. Give it a 30 sec rest in between cranks
Old Feb 26, 2014 | 07:37 AM
9228.bobcat
I reread your first post. You did the work this weekend, did it run after you did the work? Or this morning is the first time you tried to crank it?
Old Feb 26, 2014 | 07:40 AM
Josh Baker's Avatar
Josh Baker
ran great all day yesterday.
Old Feb 26, 2014 | 07:44 AM
9228.bobcat
Well forget about all the cranking then. Wont help. You have any readings? Blowing a ipr is not unusual when this kind of work is done. Can you get ipr.icp.readings?
Old Feb 26, 2014 | 07:53 AM
DSMMH's Avatar
DSMMH
Check for p2285
Typical ICP sensor failure indicators. Runs great one day and won't start the next.
Check to see if you have the ICP code p2285.
Had a similar issue 3 weeks ago. Started then quit. Started and ran like there were only 4 cylinders firing. Quit and would not start again. Popped p2285 code. Replaced ICP and all is well again.
Still a good idea to check FICM connectors. When I installed mine I put a small amount of dielectric grease across the face of the female (wire harness) connectors. Helps to Keep moisture out and with seating connectors into the FICM.
Ed
Old Feb 26, 2014 | 08:06 AM
Josh Baker's Avatar
Josh Baker
well this sucks...
Koeo
2 ICP
14.4 ip %
.24 ICV
cranking
27 ICP
77.6 IP%
.25 ICV
Hpop and stand pipes/dummies done last november and IPR was replaced then. you think IPR?
Old Feb 26, 2014 | 08:09 AM
Josh Baker's Avatar
Josh Baker
i already disconnected the ICP and tried to start to eliminate that and based on my reading I think that it is working properly.
Old Feb 26, 2014 | 08:12 AM
9228.bobcat
Looks as if ipr blew screen.
Old Feb 26, 2014 | 08:54 AM
Josh Baker's Avatar
Josh Baker
just pulled IPR and it came off without the screen... about to go to ford dealership to get a new IPR... sucks to be me!
Old Feb 26, 2014 | 08:56 AM
9228.bobcat
Yea its kinda of normal like I said. You can get a new screen for it instead of the whole ipr.
