Pulling Engine - Need advice
Old Feb 25, 2014 | 05:04 PM
homermandy's Avatar
homermandy
Trailering
So I am in the process of pulling my 5.4 out of my 1998 expedition. Everything is disconnected, ready to pull, but I need to make sure of something.
There are 4 torque converter bolts, which are removed, but I cannot get the torque converter pushed back enough to where the bolt heads do not protrude through the flex plate. It does push back about an inch, but there is still about 1/4 inch of bolt still through the plate. It is definately loose and not corroded to the flex plate.
Is this normal? Is that as far back as the converter will go? I just did not think any part of the studs should still protrude past the flex plate,.
Thanks
Old Feb 25, 2014 | 07:38 PM
alloro's Avatar
alloro
That's as far as the TC will move back. You have to pull the engine forward then lift up.
Old Feb 26, 2014 | 09:44 AM
homermandy's Avatar
homermandy
Trailering
Thanks for the advice. So when I reinstall the engine it is gonna be a pain to make sure I don't but up against the studs and damage the pump.
Old Feb 26, 2014 | 10:38 AM
alloro's Avatar
alloro
Just go slow and easy. But don't worry too much, it's a bit stronger than you think.
520SC
May 31, 2017 10:55 PM
Ryan313
Jun 11, 2016 07:19 AM
thedieselkid
May 15, 2013 05:09 AM
supercab78
Mar 19, 2006 02:30 PM
