diff tag
Old Feb 22, 2014 | 10:03 PM
ford oddity's Avatar
ford oddity
diff tag
ok
Diff tag has the following
mfbaw1e26
(8/9)15095319(B/8)
anyone have any ideas, did search and 700 pages showed up. I'm needing to replace pinion and seals behind brake baking plate, but ford had three diffs, might have to wait till Monday to see if the ford dealership can look up tag info to tell me what seals I need. But just thought I'd ask here just in case.
The bed almost patched up thanks to a buddies plasma cutter and mig wielder, need more gas will have to finish this up after filling tank Monday.
Thanks again
Dan
Old Feb 23, 2014 | 07:46 AM
Franklin2's Avatar
Franklin2
What year truck? F150 or f250? More questions to come after these are answered. And, is the rearend original to this truck? If so, what is the axle code on the door jamb sticker?
Old Feb 23, 2014 | 08:01 AM
Gary Lewis's Avatar
Gary Lewis
Answers to Dave's questions will help a lot. I tried to find info on the #'s you posted in the parts catalog but couldn't as there are too many places to look. But with some answers maybe we can figure out what haystack to look in.
Old Feb 23, 2014 | 08:55 AM
ctubutis's Avatar
ctubutis
I have never seen numbers like those on any axle tag before, they don't look like the standard Ford or Dana identifiers.
Old Feb 23, 2014 | 11:26 AM
bruno2's Avatar
bruno2
I think those numbers are the BIL and not the tag. These are the numbers stamped into the axle tubes by Dana. You need to look in a Dana catalog or call some place that deals in rear end rebuilds like Inland Truck Parts. They can access the info fairly quick.
Old Feb 23, 2014 | 11:28 AM
ford oddity
Door tags
Will look at door tags to see hopefully it has the original diff, I'm not sure where on the owners list I am.
I know the front drive shaft was replaced as it had markings from one of the salvage yards around here. Didn't see any on the rear drive shaft. Today will power wash the rear diff some more so see what markings are on them.
Currently I'm assuming there is really no outward visual differences between the 3, all internal.
Dan
Old Feb 23, 2014 | 12:04 PM
ctubutis's Avatar
ctubutis
Old Feb 23, 2014 | 12:28 PM
Franklin2's Avatar
Franklin2
Dan
There are outward differences. There are also differences if it's a f150 or f250. That would be a start, is it a f150 or a Bronco?
Old Feb 23, 2014 | 08:22 PM
bruno2's Avatar
bruno2
The BIL (build information label) is just that. I cant remember what the codes mean, but should spec everything about the differential.
Old Feb 23, 2014 | 08:59 PM
ford oddity
door sticker
1315 kg 1436 kg note g could be 6 as sun was just right to blind me when looking at this.
below that looked like the vin in a box beside the vin was
f009
tow46
diff is a ford 9 inch not dana
not sure what is going on with the garage but 1981 f150 4x4 pickup short bed ranger latriat has plastic wood on dash and broken plastic wood on door panels where window cranks are, has power locks, with slide lock for back up?
dan
Old Feb 23, 2014 | 09:02 PM
bruno2's Avatar
bruno2
Oh well I dont think the pinion seals and axle seals were different on any of the 9" rear ends. The Daytona might be different, but your pickup doesnt have one of those in it.
Here is something to think about though. If the pinion seal is bad then the bearings probably are also. When the bearings get loose the pinion shaft will wobble and ream the seal out. So more than likely you need a complete bearing set. The 9" has a third pinion bearing that helps to hold the shaft inline. So if it has worn the seal out then it more than likely does need some attention.
Old Feb 23, 2014 | 09:55 PM
ctubutis's Avatar
ctubutis
f009
tow46
What is in the AXLE field? This one has got H62; what does your say?
Old Feb 23, 2014 | 11:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1981 F150
Diff tag has the following: mfbaw / 1E26 / (8/9)15095319(B/8)
I'm needing to replace pinion and seals behind brake backing plate.
Only thing that makes any sense is 1E26 - Assembled May 26, 1981. The rest is gibberish.
EOTZ-1S177-BA (replaced EOTZ-1177-B) .. 9" Axle Seal / Obsolete
1980/82 F100 w/3,750 lb. capacity axle / 1980/86 E100/150, F150 & Bronco / 1983 F100.
E2TZ-4676-A .. 9" Pinion Seal / Marked: E2TW-4676-AA / Available from Ford
1980/83 E/F100/150 & Bronco.
Old Feb 24, 2014 | 05:25 PM
Franklin2's Avatar
Franklin2
Autozone lists 9 different rear axle seals for your truck. 4 of them are in stock at the store. You could take yours out and match it up.
They show 3 different pinion seals, one of them is kept in stock.
Old Mar 7, 2014 | 10:51 AM
ford oddity
door sticker
bottom row left to right
117 f140 fb4 k h6 cy
under the axle in blue is H6
got drives shafts in looks like that the front drives side and rear passengers tires spin first, so at this time assuming non-limitied slip or standard diffs.
