A/C Compressor Keeps Locking Up Causing No Start
Old Feb 21, 2014 | 10:03 AM
zeppelingto's Avatar
zeppelingto
Second compressor locked up and caused a no start. Any ideas what causes this. It could be a bad unit; it was a reman the second time around.
Old Feb 21, 2014 | 10:13 AM
9228.bobcat's Avatar
9228.bobcat
Has to be the unit. There may be alot of contaminants in your system. Did your first compressor burn up? If so then there is contaminants in your system and the only way to get rid of them is replace compressor and ac condenser and evaporator.
Old Feb 21, 2014 | 10:26 AM
Money-Pit's Avatar
Money-Pit
Need more info....did new compessor come with a clutch, or you had to reuse your old one?
Also, I'm pretty sure you'd burn the belt in half with a frozen compressor before it would lock up the motor, preventing it to start. Have you taken the belt off and tried to start?
Old Feb 21, 2014 | 10:29 AM
zeppelingto
Oem unit was first to go then reman. Seems like it's the bearings on the pulley not the actual compressor. There are metal shavings around the pully. Idler has sone play. Thought it might be seizing when it heats up and that could be what's dragging the compressor down with it? I guess if there was contamination in the system it could bind up the internal parts if the compressor and that could fry the bearings. Both times the AC stopped working then the compressor siezed.
Old Feb 21, 2014 | 10:32 AM
zeppelingto
Also, I'm pretty sure you'd burned belt in half with a frozen compressor before it would lock up the motor, preventing it to start. Have you taken the belt off and tried to start?
I'm pretty sure the reman was a total unit. Belt was almost glued to the compressor. Pulley is completely frozen and is pressed against the compressor
Old Feb 21, 2014 | 11:22 AM
Money-Pit's Avatar
Money-Pit
Hmm, sounds like the clutch (part of your a/c pulley) locked up shortly before it was parked last time? The weird part is it happened twice?
Your best bet would be to get a new, not reman compressor and have someone flush the system prior to installing it. Also get a new accumulator/dryer and orifice thingy. (most of the time you will have to buy these things to maintain the new compressor warranty)
I don't do A/C, but I have a friend that does.
Old Feb 21, 2014 | 12:23 PM
69cj's Avatar
69cj
Orifice tube. Parts stores here will give a 90 day warranty usually and 1 year if you also replace the dryer and tube. All the items must be on the same receipt.
DidieX
Nov 13, 2015 01:03 PM
octaneforce
Mar 22, 2009 01:49 PM
TheRobIdentity
Aerostar
Aug 5, 2006 04:30 AM
ubermich
Jul 2, 2004 03:29 PM
samralh
Mar 11, 2004 07:04 PM
