Lokar shifter install help
Old Feb 19, 2014 | 07:21 PM
ldouble619's Avatar
ldouble619
I installed my lokar shifter today and I'm having some trouble...
Tran is a C6 that was setup for column shift. So the original lever is pointing down and pushed all the forward (towards the front of the truck).
Problem is the lokar shifter locks in drive, which according to lokar and everything online it should lock in neutral. I have tripled checked this by disconnecting the rod and shifting them individually and reconnecting the rod..
Old Feb 19, 2014 | 11:16 PM
smallello's Avatar
smallello
Are we there yet?
Can you post a picture of the set-up? Are you using a cable or linkage rod?
Old Feb 20, 2014 | 08:42 AM
56panelford's Avatar
56panelford
My Lokar shifter locks in both park and neutral. Mine is cable driven and 700r4
Old Feb 20, 2014 | 10:20 AM
The Outlaw's Avatar
The Outlaw
I had a similar issue with mine on a C4 tranny. Ended up that I misread the instructions and how they meant the J arm to be. So I had the J arm on backwards. So I was getting locked in drive as well.
By switching the J arm around it was causing the notches on the shifter to not fall into the correct alignment.
Old Feb 20, 2014 | 11:05 AM
carnut122's Avatar
carnut122
Do you need to rotate the tranny shaft arm about 180 degrees?
Old Feb 20, 2014 | 05:52 PM
ldouble619's Avatar
ldouble619
Thanks for the replies. It was the lokar leveler position on the trans. I had it at about 3oClock and it need to be around 12-1 o clock.
Old Feb 20, 2014 | 06:22 PM
3golfjack's Avatar
3golfjack
This is my c6 in park using Lokar linkage. I must be going brain dead I'm showing kickdown linkage. Would delete if I knew how.
[/IMG]
Last edited by 3golfjack; Feb 20, 2014 at 06:29 PM. Reason: showed incorrect picture of wrong linkage
ADOR
Oct 30, 2013 07:02 PM
76 F-150 390FE
May 3, 2006 09:44 PM
mleichtle
Dec 2, 2005 11:47 PM
Polkat
Oct 9, 2005 08:55 PM
ladewigm
Feb 4, 2003 10:36 AM
