Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2.5 L Piston Slap
Old Feb 19, 2014 | 01:55 PM
matty.russ's Avatar
matty.russ
2.5 L Piston Slap
Hey everyone,
In January I had the engine replaced on my 2009 Ford Escape 4 cyl. They replaced the long block under warranty. However, it's been about a month, now I have no warranty and I have noticed that at cold start after sitting overnight (at only about 0-7 degrees Celsius, maybe 40-42 degrees Fahrenheit) I always get a knocking sound for about 1 to 2 minutes. It's sounds like piston slap. I've only put 1500 km on the engine and got a oil change at my dealer to see if it would get rid of the issue; which is still present.
Is this normal for the engine?
What kind of pistons/ piston skirts are on this engine?
Is it an issue?
Should the dealership take care of this problem with no cost to me?
Also, at warm idle when I am standing beside the car I can hear a slight ticking sound almost all of the time. It seems to be coming from the bottom part of the engine. Is this normal?
I am really getting fed up with this Ford as I have had countless issues with the thing.
Old Feb 20, 2014 | 08:31 AM
tomw's Avatar
tomw
Go to the dealer, and listen to a comparable model. From here it is too hard to figure out what is the source of the noise.
If abnormal, there should be a factory 90 day/3,000 mile warranty as a minimum. If it was replaced under warranty, a Ford approved re-man company was used, and they should stand behind their engine. The dealership should pay for the labor involved, just as if you had bought the engine from them. IMO. You may have to talk to a 'zone rep' who will listen to your story and make a decision.
tom
bradbelcher
2009 - 2014 F150
18
Apr 29, 2016 05:44 PM
Jen524
2009 - 2014 F150
Mar 24, 2016 05:21 AM
the_harleyryder
2004 - 2008 F150
18
Mar 26, 2008 03:10 AM
jsmile992000
2004 - 2008 F150
19
Jan 15, 2008 11:43 AM
jjsj38
4 Cylinder Engines
Apr 13, 2006 10:29 AM
