Well, not even 10,000 km on the Dealer installed roush internally cooled supercharger, and cylinder #4 has no compression, #6 piston melted, and a hell of a tick coming from the bottom end..... new engine is the only fix. Caused by nothin other than roush's supercharger, I am left footing the bill for a new engine, no recourse from roush... I heavily recomend never dealing with this company, Im out at least $14,000 for the dumbest decision ive made in a long time, clicking onto Roush.com....
Roush has a 36/36 warranty from the original inservice date so your stating that they will not honor that or that the vehicle is out of the warranty period?
No, the truck was an 05, had about 96,000km on it when the roush kit was put on, so the warranty from roush only coners the charger itself for 12 months or 12,000 miles. The pcm screwed up on the truck a couple times, causing it to run lean, but they say the charger never failed, so there is nothing they will do. So I guess just take warning when adding a kit to a vehichle that is no longer under ford factory warranty, and I think if i had a supercharged truck near end of warranty, I would be selling.... I never even had the chance to drive this thing like it was charged, nuthin but problems from two weeks after install...
Has anyone been able to diagnose the PCM problem? (I extremely curious about this because I have been tossing around the idea of buying one). I know some of the folks on here run them and seem very pleased with the overall performance.
I would really interested to know if the program was at fault, the PCM was just defective or some outside source caused the failure? Were you using a custom program (or programmer)? Have you talked with Roush and had them assist in determining what the actual problem was (or is)?
several questions come to mind--how was the truck driven? if you keep the pedal to the metal then likely what you had happen is a given-especially with the mileage on your truck.
also was the lower engine beefed up for this install? if not then the above comment would also apply again with the mileage on the truck.
third the roush warranty just says that the supercharger is warranted --not warranting that the engine will not blow.
in my opinion adding an aftermarket performance unit like this is just asking for a big problem since the eengine is not designed or intended for this type of use (or abuse if not driven sensibly.
just my 02 worth
jim
I'm confused... you say the PCM screwed up a couple of times, causing it to run lean. What does this mean? What happened? Who installed it?
I don't think the motivations ought to be questioned... no different than someone buying a truck and deciding later to lift it, build it for off-road, etc. Its their toy... they play with it the way they want.
first off...you said it was a problem from two weeks after it was installed...then you said you drove it 10,000 km's till it blew? why would you do that? secondly.....hundreds if not thousands of people have rouch chargers installed.....even ken on here has one on his truck and hasn't blown the motor....so i think it may have other factors than just the charger...
His Fords do quite well in NASCAR, and he's a long-established name in the automotive world. His products and workmanship are tested daily in motorsports all over the world. I remember Gapp and Roush running in Pro Stock in the 70's.
When you modify any engine--particularly with something that increases the stresses on that engine by 50%, you need to be aware that there are risks involved, and if something, like your fuel mixture, is not right, it can get catastrophic mighty quick. I've known drag racers to blow up an engine during the first weekend of racing, and the warranty they have is typically "if your engine blows up into a thousand pieces, all the pieces are yours"...
I'm sorry to hear that you're out of a pile of money, but, as they say, that's racing... Hell, stock motors blow up too; I had a timing chain let go on a 305 small block Chevy in my '86 GMC van back in 1990, 42k on the motor, and it was toast. Just driving down the freeway.
