Pulled the trigger, Going HEI
Old Feb 18, 2014 | 12:25 PM
reamer's Avatar
reamer
For $59.00 getting the complete HEI dissy and 8mm wires.
So it beats the $70 Duraspark dizzy and $30 Duraspark coil.
Guess I'll post the NOS Blue grommet Duraspark module and Harness on the classifieds. Along with the 3 TFI modules too.
Thanks All
on all the info on the ignition systems!
Old Feb 18, 2014 | 07:01 PM
KsCop's Avatar
KsCop
I have a how to on the HEI (I used the DUI version) conversion. The key thing for me was using an ignition relay to provide enough juice to the coil. Easy conversion though.
I replaced the feedback carb with normal one as well. Pulled the computer, converted the emissions that are left to vacuum control and the truck has never run better.
Help here if you need it..
Old Feb 18, 2014 | 07:10 PM
Gary Lewis's Avatar
Gary Lewis
Sent you a PM about the module. Forgot to mention the harness.
Old Feb 18, 2014 | 09:28 PM
reamer's Avatar
reamer
Thanks Ks, Once I get a crossmember, I can hang the new gas tank, I will not install the new 2121 intake and Edelbrock 4V with the rust-holed gas tank.
As mentioned before once it is running with the new 4v (on the TFI system), then it's time for the HEI Dizzy swap.
86straight
May 22, 2016 11:32 PM
comochja
Apr 4, 2006 12:10 PM
Steven D
Bronco II
Jan 8, 2006 07:27 PM
joegeoghegan317
Dec 11, 2004 11:36 AM
Motorcraftsman
May 28, 2000 09:30 PM
