Level Kit Opinions
Old Feb 18, 2014 | 09:13 AM
wedge88's Avatar
wedge88
Level Kit Opinions
I just bought a new 13' FX4 and have always put level kits on my trucks. This one will get a new Autospring front and rear setup (I have had 3 from Autospring) and they are great. My question is I am seeing about a 1 3/4" rake currently from back to front so I was ready to order the 2.5" front and 3" rear block that lifts the rear 1.5". This would leave a slight 3/4" rake which is what I want because I tow a lot but in reading other reviews I see the FX4 gets more raise out of the level kit so many are reporting a 2" spacer is actually giving them 2.5" lift. Are others seeing this because if so I need to drop to the 2" front.
Old Feb 18, 2014 | 02:44 PM
NASSTY's Avatar
NASSTY
My FX4 got 2" of lift from a 2" Autospring (front only) kit.
Old Feb 19, 2014 | 03:17 PM
Stangfire's Avatar
Stangfire
I'm doing mine on Friday and will let you know my results. I also measured 1.75" rake.
I think I'm doing 2.5" front and 1" rear. This should give me 0.25" rake. I measured my heights and the wheel well.
Old Feb 20, 2014 | 01:41 AM
svt2205's Avatar
svt2205
Just in case you're not aware, disconnect the negative battery cable before doing ANY steering/suspension work on a F150 with EPAS (electronic power steering). Failure to do so will damage an internal relay in the steering rack assembly and it costs BIG bucks to repair.
Old Feb 20, 2014 | 08:30 AM
wedge88's Avatar
wedge88
Would appreciate the feedback. I should have just done the upgrade but a rainy night at home put me on the forums which is always good and bad. Do you have the FX4 as well. Seems like so many different rake sizes between models and trucks.
Old Feb 20, 2014 | 08:42 AM
Stangfire's Avatar
Stangfire
Mines a 2012 XLT (XTR), 5.0L with 6.5’ box. I wouldn’t think the FX4 should be any different. I think the suspension and everything is the same.
Old Feb 25, 2014 | 03:14 PM
Stangfire's Avatar
Stangfire
So I ended up with 2.5" front lift and 1.5" rear lift. It should put me at 3/4" rack. I have not had time to measure properly yet but it looks and sits great. I'll put a pic in the other thread.
Old Feb 28, 2014 | 07:48 AM
Bleeckeraz's Avatar
Bleeckeraz
For added towing
I did the same on a 2012 XLT 4x4 with the 6.5 bed AS 2.5 frt w/ 3 rear block, and for towing I added the helwig add a leaf kit, with some adjusting it works great, no squatting with a trailer
Old Mar 1, 2014 | 05:39 PM
PDX-F150's Avatar
PDX-F150
I just put the Autospring 2.5" spacer / 3" block on my 2013 F-150 limited. I have a 3/4" rake, which is perfect because I tow a boat.
Before I ordered this kit I measured how much the truck would sag with the boat trailer on, and it was 3/4" so I should be level with the trailer on.
CO Wapiti
Apr 7, 2019 11:16 PM
Doc73
2004 - 2008 F150
Apr 29, 2013 11:14 PM
BURNSTOUGHFORD
2009 - 2014 F150
Jan 28, 2013 11:00 AM
F350SD
Mar 8, 2007 06:17 PM
nvrenuff
Oct 3, 2006 02:09 PM
