possible vacuum leak? need some input
Old Feb 17, 2014 | 06:38 PM
fordguy62's Avatar
fordguy62
I have a 1979 f250 with a 351w/c6 auto/ and 2wd ive noticed a "hissing" sound (what I believe is a vacuum leak) coming from the rear of the engine. when I start the truck I have to hold the throttle till it warms up or else it will stall out. Also when I push the brakes or turn the wheel the rpms drop. idk if that has anything to do with the sound but im giving you all the info on my truck.
I currently replaced the vacuum advance valve thinking that was the problem but it still does it. I checked all the lines and they don't have any holes. im thinking maybe egr valve or the vacuum tree
any help or input is appreciated
Old Feb 18, 2014 | 07:57 AM
Wbruiser2's Avatar
Wbruiser2
Trying disconnecting the vacuum hose from the booster and plugging it. Start the truck and see if the hissing is still there.
Old Feb 18, 2014 | 12:22 PM
fordguy62's Avatar
fordguy62
hey thanks for telling me that I noticed a small hole right near the vacuum tree that I missed while I was back there
what's the best fix for that? a new line?
Old Feb 18, 2014 | 07:22 PM
Gasman303's Avatar
Gasman303
I found my vacuum leaks by spraying carb cleaner on all my vacuum lines... Once my idle would raise then I would concentrate on that general location until I found my bad hose. I also hear WD40 works well?!!
Old Feb 19, 2014 | 08:20 PM
1974 f100's Avatar
1974 f100
I have a 74 f100 w/360 2v. Had a similar problem about a month ago. Apparently the PVC fitting (huge) on the back of the carb had somehow become dislodged. There may be some fasteners back there but it is almost impossible to see. I just pushed it back into place and now runs great.
workingdog
13
Nov 17, 2005 08:14 AM
FordandSkeeter
Jan 28, 2005 09:03 AM
LV Dan
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 8, 2004 07:38 PM
LV Dan
Sep 7, 2004 03:17 PM
