Possible throwout bearing issues?
Old Feb 18, 2014 | 07:27 PM
TruckNorris250's Avatar
TruckNorris250
My 78 f250 4x4 with a 460 mounted to a 4spd from my old 351m and I'm hearing some crazy noises underneath the truck when the clutch is engaged. It sounds like a grinding noise but I don't know how else to describe it. My dad says it's the throwout bearing but I would just like some more input before I decide to pull the transfer case and transmission
Old Feb 18, 2014 | 07:41 PM
hickory1991's Avatar
hickory1991
Throwout bearing and or pilot bushing. Have someone push on clutch while you look under and listen to see if you can pinpoint where grinding sound is coming from. Neal down beside truck, don't get under it.
Old Feb 18, 2014 | 07:47 PM
lucky_thirteen's Avatar
lucky_thirteen
Throwout bearing
Old Feb 18, 2014 | 08:04 PM
TruckNorris250
I was afraid that was the case. I'm concerned that my exhaust is too close to the bellhousing to get it off so I guess I'll cross that bridge when I get there. I think a wobble socket might let me in there
Old Feb 18, 2014 | 08:22 PM
devino246's Avatar
devino246
Back up a second. Are you hearing the noise when the clutch is engaged or when the pedal is depressed?
Old Feb 18, 2014 | 08:28 PM
Undertheoaks's Avatar
Undertheoaks
I too have the same problem, on my 78 f100 w/302 4sp Granny first. I hear it when the clutch pedal is depressed and in 1st gear when clutch is out ? Was planning on replacing throwout bearing and bushing, how hard is this to do ? And should I replace clutch at same time even if it's good since I have it apart ?
Old Feb 18, 2014 | 09:41 PM
TruckNorris250
When the pedal is depressed, sorry I should have specified. Mine is having the same issue as yours Underthoaks. I'm not gonna change my clutch because I just replaced it when I did my swap which was only like 2 years ago. The clutch still works fine and seems fine but if I take it apart and I find a problem then I will replace it
Old Feb 19, 2014 | 08:42 PM
TruckNorris250
How long can I drive on it like this without causing damage to other parts? I have to drive at least another hour and a half and 45 minutes of that being at 70 mph in order to get home to my shop
diesel85
Dec 3, 2015 10:01 AM
oldblue89
Jan 6, 2013 10:01 PM
skuteman
Mar 19, 2005 07:12 AM
1ole4d
Dec 28, 2001 10:28 AM
