Vaccum Advance
Old Nov 15, 2005 | 07:34 PM
workingdog's Avatar
workingdog
Vaccum Advance
We been having a hard time getting our recently rebuilt 390 to run smoothly in our '68 F250 until we disconnected the vaccum advance. Now it idles and revs great. Any idea what that indicates?
Petre
Old Nov 15, 2005 | 07:45 PM
fordraceboy's Avatar
fordraceboy
a hole in the vacuum can creating a vacuum leak... first guess..
Bear 45/70's Avatar
Bear 45/70
Where was the vacuum advance hose connected to? It sounds like you were connected to manifold vacuum instead of carb ported vacuum.
Old Nov 15, 2005 | 07:47 PM
ford390gashog's Avatar
ford390gashog
do you have the vacuum line running to a ported vacuum? because the vac advance won't affect it at idle.
Old Nov 15, 2005 | 07:51 PM
workingdog's Avatar
workingdog
It's definatley not connected to the manifold, but we may have it connected to the wrong outlet on the carb.
Old Nov 15, 2005 | 07:52 PM
ford390gashog
yep probably. base timing should be 12 btdc.
Old Nov 15, 2005 | 08:30 PM
fordeverpower's Avatar
fordeverpower
workingdog, the carb has a manifold port and a ported port. The manifold port is below the throttle blades and the ported is above them.
Old Nov 15, 2005 | 09:44 PM
Bear 45/70's Avatar
Bear 45/70
When you plug in the vacuum advance hose onto wherever, does the engine speed up? If so, wrong port.
Old Nov 15, 2005 | 09:51 PM
workingdog's Avatar
workingdog
No, the engine starts to stall.
Peter
Old Nov 15, 2005 | 09:56 PM
ford390gashog
are you sure you have the timing and mixture set right?
Old Nov 15, 2005 | 10:00 PM
Bear 45/70's Avatar
Bear 45/70
By stall I assume (very bad thing to do) that you mean the rpm drop off and the ingine splows down. Is this a dual diapham advance unit with 2 nipples on it? Is the vacuumat idle on the port you are connection the hose to on the carb?
Old Nov 16, 2005 | 03:03 PM
workingdog's Avatar
workingdog
So we got the basic timing done (it was OK to begin with) and the mixture and idle set roughly and we got the vacum line connected to the right port on the carb so it does not effect idle. When we rev the engine with out the vacum advance connected it runs great, when we connect the vacum advance it stumbles when we rev it. Is my vacume advance bad? Can I just leave it disconnected?
Old Nov 16, 2005 | 05:07 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Is this thing points? Almost sounds like the upper bushing is shot, and the vacuum advance pulling the plate around is sending the dwell out the window.
Or if it's a Duraspark, you have a broken wire to the pickup.
Old Nov 17, 2005 | 08:14 AM
workingdog's Avatar
workingdog
Yes, it is points. We'll take a look at the upper bushing.
stinger57
Nevada Chapter
Dec 20, 2016 08:26 AM
shotgun2
Nov 19, 2016 10:32 PM
formula74
2004 - 2008 F150
May 1, 2016 07:11 PM
Buyerz
Dec 24, 2015 12:10 PM
scoop75
1997 - 2003 F150
Sep 14, 2008 10:57 PM
