Vacuum Leak Elusive
While trying to find the vacuum leak, I thought I narrowed the problem down to air leaking through the Electronic Vacuum Regulator (EVR). After a fellow FTE member told me that the voltage needed to be applied to close the valve, I tested the EVR with the engine running, but it still leaked air into the vacuum lines. So I replaced the EVR and the new one does the same thing.
I checked the voltage across the EVR with the engine running. There is around 12 volt across the connector and using an AC meter I determined there is an AC component which makes me think it is getting a pulse width modulation. But I don't know if it is the correct signal it should be getting.
With the engine running, will the EVR normally allow air back into the vacuum source lines?
When I put a vacuum on the manifold connection for the EGR and A/C system, it will not hold a vacuum at all. When I plug the source line to the EVR, the vacuum will reach to about 2 in.mg. with a lot of pumping and will drop to zero over a few seconds. With the vacuum line to the EVR and the Vapor Management Valve plugged, it will go well over 20 in.mg. and hold forever.
If anyone has some insight for me, please let me know.
https://www.ford-trucks.com/forums/s...53&postcount=6
NOTE: The A/C vacuum reservoir tank and bracket is located either on or beneath the RH front fender splash shield.
PS. i have been told thid is not a Ford problem only, was told The bowtie people have the same design. (may not be right though.)
