1978 - 1996 Big Bronco
Knocking
Old Nov 18, 2003 | 02:53 PM
buckeyebronco's Avatar
buckeyebronco
Knocking
Know I may sound dumb but what exactly does knocking or pinging sound like? I have a noise that sounds like a peice of metal just hitting against the engine, not a constant thing just every once in a while.
Old Nov 18, 2003 | 06:09 PM
3broncocrazy's Avatar
3broncocrazy
I'll try to take a stab at it.
The knocking sounds like "knock, knock, knock, knock" and would increase or decrease with RPM's
Pinging "could" only happen when giving it the gas or underload - sometimes cheap gas or timing off.
Have you checked exhaust, exhaust shields etc?
Forgot, NO exhaust..........Maybe a/c compressor?
Old Nov 18, 2003 | 08:09 PM
AYoungblood's Avatar
AYoungblood
3dBroc, what does the exhaust have to do with it?
J/w?
Adam
Old Nov 19, 2003 | 07:11 AM
3broncocrazy
youngblood - Nothing, 'cept i've been breathing too much from one of my '79s
You ever tried to type with a few buds...........sometimes don't come out wright
Someone please help with the pinging sound, please
Old Nov 19, 2003 | 07:31 AM
Sport45's Avatar
Sport45
Help me out here. The signature says no exhaust, just pipes. Aren't pipes part of the exhaust system? I'd still take a look and see if they're hitting something or loose in the manifold (or head, whatever).
Old Nov 19, 2003 | 10:42 AM
buckeyebronco
Exaust is fine, nothing hitting but the ac compresser might be it. at an idle and sometimes driving it just kicks in, even when the heat is on. So I think the clutch is out. Anybody know how to replace one?
Old Nov 19, 2003 | 11:01 AM
kilted_drummer's Avatar
kilted_drummer
did you check to see if it is the connector to the ac compressor? I know mine had broken under previous ownership, not sure how it snapped clean off. I was barely connected causing sporadic operation. If the compressor is coming on when not intended to be coming on, it is more likely electical, ie swith, connector wiring. Have you looked at the fan clutch? I have had that problem before also, and made a similiar noise.
Old Nov 19, 2003 | 04:29 PM
3broncocrazy
So not knocking, or pinging - it's more like clicking........Come on youngblood, you can make the sound "you can do it"
Sorry, just having fun
Good luck buckeye - might want to post in a/c section for help with the a/c cluch or a/c elect.........I'm only the sound advisor
LOL
Old Nov 19, 2003 | 08:38 PM
AYoungblood
No man, i was serious, I was seriously wondering what you meant.
Im here to learn, honestly im on 19 and just now truly getting into this stuff. And I assume most of you, by the way it sounds have a lot of experance under your belt.
Im just trying to learn as much as I can.
Adam
Old Nov 19, 2003 | 10:42 PM
Trucky18's Avatar
Trucky18
some of us are younings to
Old Nov 20, 2003 | 04:59 AM
3broncocrazy
youngblood,
just having fun and trying to narrow the sound down.
Buckeye,
did you determine if it was the a/c cluch.........
if didn't want to have fun, wouldn't be driving fords
Old Nov 20, 2003 | 10:05 AM
buckeyebronco
yeah i think its something with the ac compressor so ill have to check that out. thanks guys
