T19 leaking
Old Jun 30, 2003 | 08:12 AM
mchild's Avatar
mchild
T19 leaking
I have an `85 F350 2wd with a T19 4 speed trans. I have a trans leak coming from the seam of the rear housing to the main housing. I assume it is a bad gasket although the trans is freshly rebuilt.
My Haynes manual does not provide much info on repairing these trans, but it does show an exploded view of a T18 which looks very similar.
From looking at the exploded view it seems pretty straight forward to remove the rear housing. Remove cross member, drive shaft, output flange, speed-o cable, and four bolts holding the rear housing on. Is that all there is? Are these units known for leaking at this spot? Is it okay to put a bit of RTV on the new gasket?
Thanks for any help you can provide,
Mark
Old Jun 30, 2003 | 01:01 PM
steve83's Avatar
steve83
T19 leaking
Read this.
Old Jun 30, 2003 | 01:14 PM
mchild's Avatar
mchild
T19 leaking
Thanks Steve but, while the site went into good detail on the gear box it did not cover anything on the extension housing other than showing the rear seal installation tool. There was no discussion/pictures on removal or installation of the housing itself or the gasket sealing between the gear box and the extension housing.
Thanks,
Mark
Old Jun 30, 2003 | 10:55 PM
steve83's Avatar
steve83
T19 leaking
OK Try this one.
Old Jul 1, 2003 | 09:27 AM
mchild's Avatar
mchild
T19 leaking
Thanks Steve I'll check it out.
Jungle4jim2
May 9, 2018 07:35 AM
Adam Woolridge
Nov 23, 2015 10:48 AM
rock2610d
Sep 26, 2015 09:44 PM
Viper2F350dually
May 4, 2011 02:35 PM
skyrader
Jul 31, 2008 03:57 PM
