Temp gauge doesn't work
Old Feb 16, 2014 | 08:34 PM
itsmyyname's Avatar
itsmyyname
2005 Ford E350 6.8 V10 van overheated cause temp gauge didn't work blew intake gasket, fix that but now I need to get the gauge working so the costumer can get the van back.. It has a new Coolant Temp Sensor and another instrument cluster still doesn't work.. If I ground out the connector the gauge will shoot up to HOT, I put a power probe on the connector and I have a good ground when I check the + wire I dont even get 1volt.. Not sure what to do from here...
Old Feb 17, 2014 | 06:01 AM
JWA's Avatar
JWA
Is your replacement cluster of the same model year or a known compatible part? That could be a minor issue although it would seem you have a problem with the wiring.
I'd check continuity between the temp sender connector and the corresponding terminal on the cluster connector. That's probably where your problem originates.
Do you have an OEM EVTM?
Old Feb 17, 2014 | 08:12 AM
itsmyyname's Avatar
itsmyyname
Pretty sure the cluster was from the same year model.. and the reason it was replaced is cause the temp gauge wasn't working but turns out it works when you ground out the connector.. But my Power Probe is showing it has a ground..
Old Feb 17, 2014 | 12:48 PM
Frozen_Joker's Avatar
Frozen_Joker
So if that is the case, just run a new ground. Extra grounds never hurt anyone!
Old Feb 18, 2014 | 10:30 PM
itsmyyname's Avatar
itsmyyname
After tanking the van down the hwy for about 15min I ran a wire off the sender itself to the block and the gauge never went up... there's a green and red wire going to the sender grounded the green wire to the block and it shot up to HOT
https://www.youtube.com/watch?v=IDwnwtbPSIw&feature=youtube_gdata_player
Old Feb 18, 2014 | 10:45 PM
Frozen_Joker
Doesn't look like an actual overheat. Just a faulty ground. So are you saying you ran new ground and its better now?
Old Feb 18, 2014 | 11:49 PM
itsmyyname's Avatar
itsmyyname
No... in the video that's grounding out the green wire.. if I run a ground directly from the sending unit to the block the gauge doesn't move..
Old Feb 19, 2014 | 10:54 PM
itsmyyname's Avatar
itsmyyname
Noticed earlier while looking at the van seen some fresh looking electrical tape on the temp sending wires took the take off and someone had spliced in a new connecter so figured maybe they got the wires wrong so swapped the wires and drove it and it never moved... I'm put my power probe on the wires one wire I have a ground and the other I'm getting like 0.2 to 0.4 volts....
Old Feb 20, 2014 | 10:13 PM
itsmyyname's Avatar
itsmyyname
triple post i know but does anyone have a clue what my problem could be,..
InfantryCPT
29
Apr 15, 2015 01:19 PM
kennisonxgs
Nov 7, 2014 10:40 AM
Nuj79
Feb 6, 2007 11:57 PM
Martys82
Jan 31, 2003 05:14 PM
