Holley 4160
Old Feb 19, 2014 | 02:33 PM
MdubbU's Avatar
MdubbU
I don't think pinesol cause any discoloration so you should be good to go. I think you can let it soak in it for a few days to with out having to worry about it. I would spray it down with brake cleaner after you pull it out just to make sure every nook and cranny is as clean as possible.
Old Feb 21, 2014 | 03:05 PM
aj3501's Avatar
aj3501
I let it soak for a few hours, scrubbed it with a green scotch pad, made a new batch of pinesol and water and let it soak over night and repeated the green pad. Then sprayed it all down with a carb cleaner
Old Mar 6, 2014 | 10:49 AM
aj3501's Avatar
aj3501
Any one have a good picture of the throttle return springs and brackets, i have the rear on installed but i can't see to find where the front spring connected to or the bracket for it
Old Mar 6, 2014 | 10:57 AM
MdubbU's Avatar
MdubbU
it depends on you engine and throttle cable type. I still have to figure this out for mine to cause none of the stock stuff would work with the new intake manifold and carb. but to attach the cable you need the ball stud on the side of the throttle plate.
Buckhorn2
Jan 9, 2018 01:01 PM
flyflinger
Nov 16, 2005 11:52 PM
Chumbucket
Sep 27, 2005 03:12 PM
Crumm
45
Nov 5, 2004 02:54 AM
levilevi2
Sep 19, 2003 03:33 PM
