Dana 60 install
Old Feb 16, 2014 | 02:07 PM
grappler211#'s Avatar
grappler211#
Dana 60 install
I have a 1978 F-250 with a D-44 in it. I'm replacing it with a D-60 from84. I know how to modify the spring mounts on the frame for the new width of the axle. I'm not sure how to make the steering work. I have a forward push pull gearbox but the new axle needs a left to right motion. what is the easiest way to fix this can I rotate the pitman arm on my gearbox? Thanks for any help.
Old Feb 16, 2014 | 08:49 PM
tabascom16's Avatar
tabascom16
Sell that D60 and spend the extra cash on the correct one. Just curiosu why you want to go from the D44 to the D60? Yes there is bigger ujoints and bigger inner axles but the outer shafts are the same diameter on both units.
Unless you are constantly breaking something the upgrade isn't getting you much. I went from a D44 to D60 because I found one for next to nothing but all it really is is a discussion point/bragging rights with others. "Oh nice...you have the D60 front end!"
You are going to spend more time and money trying to make that 84 D60 work than it is worth. The drivers side spring mount is cast into the center section, so if you use it the axle will be off center to the passenger side.
If you try and center it you are going to have to rig your leaf springs up which I don't even want to think about the concerns associated with that. Then add your steering dilema.
I just don't like the sounds of it all to save a few hundred dollars if you are lucky.
Old Feb 16, 2014 | 11:33 PM
grappler211#
I have broken everything in the front end of that d 44. Every axle more than once and the ring and pinion. 39.5 tires power lock diff and about 500 hp not good for a d44. Every pro I talked to about better axles ect.. all told me move up to d60. Randys ring, Mosser and a few off road shops said I would break d44 chrome molly axles and if not then the ring would blow up. I need to move the springs out 2.5 inches each side and I know the easy way to do that. just not sure about the steering. Looked at randys ring and a d44 weighs 4.2 lbs and a d60 weighs about 8lbs for the outer stub shafts.
Old Feb 17, 2014 | 07:45 PM
tabascom16's Avatar
tabascom16
I cant remember if the pitman arm has an index key in it. It may not. Worse case if it does you could shave them down to clock it 90 degrees? I don't know if splines from the steering box are keyed. It might not be but likely is so operators at the factory cannot put the pitman arm on incorrectly.
You would then need something like this below. it is a high arm kit for rock crawling. I could not specifically find it for Ford but they might be able to make one for you.
GM/CHEVY/JEEP DANA60 COMPLETE 1-TON CROSSOVER HIGH STEER KIT- W/PITMAN ARM/STUDS
Old Feb 17, 2014 | 10:53 PM
brian1080's Avatar
brian1080
I bet they were referring to the 78-79 D60. That's the one people love.
GearCrazy
15
Apr 27, 2010 11:36 PM
jimjoebob99
27
Dec 28, 2009 07:25 AM
4x4xbigassford
Aug 21, 2008 02:08 PM
wyldstallyn73
Offroad & 4x4
Jul 14, 2005 04:02 PM
mustange70
Offroad & 4x4
Dec 21, 2004 07:31 PM
