Sponsored by: Real Truck
Please help
Old Feb 16, 2014 | 11:14 AM
expensive_habit's Avatar
expensive_habit
Question Please help
Hi, I'm new here and maybe you guys have already solved this problem... I have an 03 F250SD with ~145,000 miles on the 5.4L. Just recently I have been having what seems to be a miss, or possibly a dead cylinder. I thought it might be a dirty MAF, but I cleaned it and have the same problem. The miss is more noticeable at the higher RPMs. I am checking the plugs today. So anyways, has anyone come across this problem, and does anyone have a solution? I refuse to take her to the shop and having another man up in her manifold.
Old Feb 16, 2014 | 11:33 AM
02TB250's Avatar
02TB250
When is the last time you changed the fuel filter and plugs?
Sent from my Galaxy using IB AutoGroup
Old Feb 16, 2014 | 11:37 AM
expensive_habit
I changed the fuel filter about three weeks ago. I haven't changed the plugs since I bought it a couple of years ago. I know it's bad of me, but I've been really busy, and they are a bit of a pain cause of the fuel rails on top of the coils
Old Feb 16, 2014 | 12:33 PM
02TB250's Avatar
02TB250
You'll want to check the coils, and you only need to change then if they don't work. You'll want to change the plug boots.
You also well want to check the coolant and the oil to make sure nothing is up with them. A headgasket can cause misfire symptoms
Old Feb 16, 2014 | 12:36 PM
Quad Racer's Avatar
Quad Racer
My van with a 5.4 ran like that right before it blew a plug and also right before a coil went. Any codes to speak of?
Old Feb 16, 2014 | 12:53 PM
expensive_habit
I'll defiantly check the coils, and change the plugs. I'm pretty sure it's not the head gasket, but I can test the compression. Quad Racer, the funny thing is that there are NO codes, When I scanned it all I got was a yellow emission light (fair).
Old Feb 16, 2014 | 01:03 PM
Uncle Phippy's Avatar
Uncle Phippy
The first thing you need to do is run codes to find out which cylinder is misfiring. If you don't have a code reader, you can go to a parts store and most of them will do it for free. Once you have determined which cylinder is misfiring, simply change that cylinders coil with a coil from a cylinder which is not misfiring. Then drive the truck and read codes again. If the misfire moves to the cylinder that previously did not misfire, it is the coil. If the misfire remains at the original cylinder, it is most likely the plugs. It is not an easy job, changing the plugs. It took me six hours, however, I did a thorough job of cleaning everything, applying di-electric grease to the coil boots, and applying anti-sieze to the new plugs. Be sure to torque your plugs when installing them. Don't over tighten.
Old Feb 16, 2014 | 01:07 PM
Uncle Phippy
Sorry expensive habit, I didn't see post #6 before I posted. Strange you have a misfire and no codes.
Old Feb 16, 2014 | 01:12 PM
expensive_habit
That's what is throwing me off. I just hope it's nothing more serious. Thanks again for all the input!!
ChrisCarter
2004 - 2008 F150
22
Oct 21, 2010 09:53 PM
99rangerXLT
1983 - 2012 Ranger & B-Series
Feb 7, 2007 10:27 AM
brockinfla
13
Oct 30, 2006 02:39 PM
IPACA9
Oct 13, 2006 02:18 PM
Drizzt
3.8 & 4.2L V6
Mar 19, 2004 05:28 PM
