i lost all the bump stops .....,,,,,,
Old Feb 15, 2014 | 07:53 PM
mr.noodi's Avatar
mr.noodi
I didn't find any bump stops under my truck , it's like never their at all . Even those setting on the leaf springs .
Any way which brand should I go with , and are they all have the same sizes , the body and the leaf bump stops .
Thanks
Old Feb 15, 2014 | 07:59 PM
johntpr's Avatar
johntpr
The front bump stops are part # 2c7z3020aa
Old Feb 15, 2014 | 08:14 PM
mr.noodi's Avatar
mr.noodi
How many bump stops are there.
And out off topic Q : are happy with your sway bar , does it effects the ride quality on bumpy roads , because am about to buy one .?
Old Feb 15, 2014 | 09:38 PM
johntpr's Avatar
johntpr
On the front axle there is a bump stop on drivers and passenger side.
The Hellwig rear sway bar was recently redesigned and it a great addition. It will help your ride quality. I would not hesitate to recommend it.
Old Feb 16, 2014 | 05:37 AM
mr.noodi's Avatar
mr.noodi
two on the front got it , what about the rear how many.
Old Feb 16, 2014 | 07:00 AM
xhid's Avatar
xhid
Two on the rear. Put mine on yesterday.
Old Feb 16, 2014 | 10:23 AM
EXv10's Avatar
EXv10
You won't need any of them or the bar unless you are a race car driver and it bottoms out (or towing with equalizer bars). The bar is actually a step back because it just throws you around more in the cab on uneven bumps/dips. Removing the front stops actually gives you more clearance in the front and many rear ones are missing with no ill effects.
I prefer to have the bump stops out partly because I can tell when it actually does bottom.
Old Feb 16, 2014 | 02:41 PM
mr.noodi's Avatar
mr.noodi
So it's OK to drive without them, OK what do you recommend for body rolling :-X2
and i don't tow at all .
is the new rancho xl9000 shocks going to cure the rolling issue ?
Old Feb 16, 2014 | 03:58 PM
EXv10's Avatar
EXv10
Mine doesn't roll but if you think it is a problem rear sway bars will help but no shocks will do anything for roll. Yes it is OK to drive without the bump stops, and if you have no spring wrap problem and no bottoming problem you won't need them. There is actually less chance of bottoming in the front without them because they compress to about 1/2"+- and bottom at that point so if the occasional "whack" noise doesn't bother you, leave them out.
Old Feb 16, 2014 | 06:48 PM
mr.noodi's Avatar
mr.noodi
my springs looks good no warp or cracks and shoot 3 of my shocks are busted , i'll see what happened after installing xl9000s shocks .
and will 315/75/17 BF All Terrains fit without rub or modifications ?
Old Feb 16, 2014 | 07:32 PM
EXv10's Avatar
EXv10
I doubt if those tires will work but maybe someone will chime in and the shocks won't affect body roll due to the time factor (roll vs vertical bumps).
Old Feb 16, 2014 | 07:57 PM
mr.noodi's Avatar
mr.noodi
you know when am driving slowly then hit some road bump my truck swings like baby bed , for me I don't mind but My mother broke her hip 6 months ago that the swing is harsh for her and bit painful , I want her to be comfy in long trips.
Old Feb 16, 2014 | 08:20 PM
EXv10's Avatar
EXv10
I would just go with some standard shocks like mine, the Monroe-Matic Plus. They do everything they are supposed to do and smoothly.
From Monroe;
Monro-Matic Plus® shock absorbers are nitrogen gas charged and feature velocity proportional valving and all weather fluid, which offers trucks improved comfort at an economical price.
MONROE SHOCKS & STRUTS: Monro-Matic-Plus - Truck Shock Absorbers
marshallstanford
Aug 14, 2016 11:56 PM
lets7777
Feb 27, 2012 09:32 PM
86F250BIGBLOCK
Aug 19, 2008 11:35 PM
Maccoupler
Jan 31, 2006 06:22 PM
jrsroadhauze
Aug 22, 2003 12:11 PM
