I lifted my 86 F250 4x4 a few months ago and instead of buying the extended sway bar links I just removed the swaybars. Since doing this I have not noticed any major difference in the ride, and I think it actually rides better since my front springs and all shocks were bad prior to the lift. If i feel that it rides fine, do you think i need the sway bars? I think its about $80 bucks for front and rear links, and I really dont feel like putting them back on. Could I experience any issues later on? Thanks for your help, Jesse.
Sway bars just keep the truck from leaning in turns. They were an option on a lot of trucks but are not absolutely necessary. It's up to you if you want to keep them or not.
You might experience a softer ride without them, because basically they keep both sides of an axle planted in the road. If both sides hit a bump, the sway bar will do nothing, but if one side drops in a pothole, and the other doesn't, the sway bar will resist this and you will notice a seat-of-the-pants difference.
Jesse, where are you? Your profile does not list your location. I have a stock hieght F250 4x4 and I would be interested in purchasing your bars if you decide to pull them. BTW, I also have a lifted '85 F150 4x4 without bars and it doesn't lean in corners. The increased stifness of the springs put a stop to all that...
Hey, thanks for the replies guys. I am located in Pittsburgh, PA. I may possibly sell them if you are close by chance. Let me know. I think I'll be fine without them.
