Front sway bar
Old Feb 23, 2012 | 10:06 PM
lets7777's Avatar
lets7777
Front sway bar
Has any one put a sway bar on a straight axle? Is it helpful? Does any one know where to source one for a '48 F-1 / F-3?
Thanks for the help.
Old Feb 26, 2012 | 02:22 PM
AXracer's Avatar
AXracer
You really don't need a swaybar with the stock parallel leaf suspension with fresh eye bushings and pins. The springs themselves act similar to a sway bar.
Old Feb 26, 2012 | 02:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You know, I've heard that before and sort of blindly accepted it, but I don't think it's true. A sway bar on the front will transfer load to the rear spring diagonally opposite it on a turn; I don't see how a beam axle or leaf springs has a similar effect. There have been plenty of OEM installations of sway bars on solid rear axles, there must be a reason. There are several people on the forum who've added sway bars to the stock fronts, I'd be interested to hear how well they work.
Old Feb 26, 2012 | 03:44 PM
tinman52's Avatar
tinman52
Welder User
I need one on my truck as well. Since I removed some spring leaves, it is kinda mushy in the corners. Some of the streetrod suppliers offer "universal" ones.....may have to go that route.
Old Feb 26, 2012 | 03:53 PM
AXracer's Avatar
AXracer
IMHO I'd spend the money on good shocks.
Old Feb 26, 2012 | 06:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Here's a past discussion (AX explains why he prefers shocks in it) https://www.ford-trucks.com/forums/9...sway-bars.html
Old Feb 26, 2012 | 11:33 PM
lets7777's Avatar
lets7777
Thanks guys for the info esp. the link. Ax; what would you consider to be "good" shocks?
Old Feb 27, 2012 | 10:19 AM
AXracer's Avatar
AXracer
"good shocks" are ones that are valved to match the vehicle's spring rate and weight with quality internal parts. What they are not is 3rd world mass produced with "one size fits all" parts with very little quality control.
Some of the better brands in no particular order are Bilstein, Koni, QA1, Tokico, Aldan.
There are still higher end shocks, Penske, Ohlen, Moton that are hand built to order, but they are better suited to racing applications.
When buying high performance shocks, you should not buy out of a catalog, but call the manufacturer's tech support department and talk to their engineers/tech staff, then go with their recommendations. They have a vested interest in providing their best product for your application, word of mouth from satisfied customers is their best advertising. Yes, quality shocks will be more expensive than the nationally advertised big box store inventory, but still reasonable, about the same cost as a set of headers and less than a set of aluminum wheels with far higher bang for the buck in performance and safety added than either.
Old Feb 27, 2012 | 09:32 PM
lets7777's Avatar
lets7777
Ax, thanks for the guidance.
majorgator
41
May 1, 2015 10:17 AM
Oxfordrider
Feb 24, 2013 08:29 AM
docholiday72tx
1947 and Older Ford Trucks
Apr 1, 2006 01:50 AM
screwloose2
Jan 30, 2006 06:53 PM
GotLift
Sep 10, 2005 01:01 AM
