Power Steering Fluid Capacity?
Old Feb 15, 2014 | 07:23 PM
IHbase's Avatar
IHbase
Power steering fluid discolored. I thought I'd drain and replace.
How much fluid do I need? Any advice on drain points or should I just suction it out at the reservoir and live with some of the old oil contaminating the new oil?
I was going to run Mobil Synthetic ATF unless someone has a good reason to run something else.
Thanks in advance.
-Mike
Old Feb 15, 2014 | 07:38 PM
Nice Work Truck's Avatar
Nice Work Truck
The Mobil 1 ATF is good.
The power steering and brake booster both use the some fluid.
It is a easy flush to do.
https://www.ford-trucks.com/forums/8...ing-flush.html
Old Feb 15, 2014 | 07:53 PM
IHbase's Avatar
IHbase
Thanks for the link. We have a vacuum evac system, I'm not much for using cooking devices. The filtration idea was interesting, but judging by the photos, most of the material collected in the filter was produced during the process of cutting the filter apart. Probably cheaper to just change the oil a couple of times rather than mess around with adding filtration capacity to a tiny hydraulic system.
-Mike
Old Feb 16, 2014 | 05:14 AM
npccpartsman's Avatar
npccpartsman
Easy as pie:
Old Feb 16, 2014 | 08:41 PM
IHbase's Avatar
IHbase
Thanks partsman: That looks like a better method than syphoning the reservoir- although, I think it could be improved upon.
1. Run longer 3/8 lines so the engine compartment is not sprayed with ATF.
2. Turn the steering box to flush it out.
Finally, I kinda doubt that changing the fluid changed the brake feel as suggested by the video.
This flush method was a good idea. Thanks for passing it on.
-Mike
Old Feb 17, 2014 | 04:32 AM
Nice Work Truck
-Mike
If your fluid is old it will improve the feel of your brakes.
Old Feb 17, 2014 | 06:07 AM
npccpartsman
-Mike
You are supposed to put the front tires in the air and turn the steering box to aid in flushing and pumping the brakes helps also. I don't think the gentleman who produced the video had the ability to do that at the time (he's a member here IIRC). The video does give a good, simple procedure to flush the fluid though, which was it's intent.
1999SuperD
31
Mar 27, 2010 08:53 AM
Scout
Mar 16, 2009 03:54 PM
Sugarbooger
Nov 15, 2007 01:19 PM
plane
Apr 19, 2006 04:03 PM
Smith76
Mar 8, 2006 09:11 AM
