Power Steering Flush
Old Apr 16, 2006 | 02:47 PM
plane's Avatar
plane
Dealer recommended this but I've never heard of anyone having to flush out the power steering system as part of a regular maintenance item. They want $75 to do it.
Reason for the recommendation is the fluid is dirty (gray colored).
2003 Explorer 4x2 V8 25,000 miles
Old Apr 16, 2006 | 03:00 PM
aquanaut20's Avatar
aquanaut20
If the fluid has a grey colour, it indicates that there is wear in the steering rack (aluminum) and if you dont do a flush you may well need to replace the unit @ substantialy more than 70.00. That being said it is a 15 min job to do it yourself.
The fluid should have a bright red/pink colour (transmission fluid), anything else, flush..
Old Apr 16, 2006 | 03:02 PM
ford390gashog's Avatar
ford390gashog
I do a PS flush every 10,000 miles. Takes me 15 mins and 3 quarts of Mercon fluid. total cost 7.00
Old Apr 16, 2006 | 05:26 PM
plane's Avatar
plane
Ok, that makes sense. Now what's entailed to do the job.
Take the lid off of the reservoir and then open the drain valve on the steering rack?
Old Apr 16, 2006 | 06:54 PM
srercrcr's Avatar
srercrcr
I've been flushing the fluid in my pickup annually for years.
It really makes sense. I wouldn't pay a shop, but do it myself.
I couldn't recognize a drain line coming off the pump, so I'm lookin forward to some instructions.
Old Apr 17, 2006 | 09:58 AM
blend-door-lover's Avatar
blend-door-lover
Yes - any directions would be very helpful fo rme too.
Thanks in advance,
Phil
Old Apr 17, 2006 | 10:05 AM
suave6565's Avatar
suave6565
Ok,
I'm looking to do this myself, but for a 1996 ford explorer eddie bauer....my steering sounds more like its missing fluid...i had a friend of mine who had his done for $50.00 bucks...His steering is alot better than mine and doesnt make as much noise when turing the wheel. he has the same year,make and model.
Where do i find the drain so i can do it myslef?
Old Apr 18, 2006 | 11:27 AM
aquanaut20's Avatar
aquanaut20
Sorry to leave you guys hanging, been away for the holidays
Instructions for P/S flush
Method 1 (dilution)
Put a catch tray under P/S pump to catch fluids
Jack front of truck up so the weight is off the wheels
Remove return line from pump (bottom rear), fluid will drain,
Reconnect hose, fill reservoir with ATF, start engine and move steering lock to lock
Stop engine and repeat until fluid is clean.
Method 2 (Flush)
Put a plug in the pump drain, leave return line disconnected and aimed at drip tray
Fill reservoir and keep full during this operation
Remove serpentine belt and rig a hand drill to turn pump, be mindful of rotation
Have someone in cab rotate steering from lock to lock
Start drill and keep fluid full while moving L/L.
When you are satisfied with the colour of the fluid leaving return line, stop drill, remove plug, reconnect the return line, top up fluid, clean up you mess..
Note: Keep fluid off pain, it will stain..
You will need about 4 Lt
Old Apr 18, 2006 | 06:09 PM
blend-door-lover
Awesome - many thanks for your time - good write up - I shall attempt this weekend.
Old Apr 18, 2006 | 10:10 PM
aquanaut20's Avatar
aquanaut20
You are welcome Phil,
this is what this forum is all about,
Regards Philip
Old Apr 19, 2006 | 06:38 AM
srercrcr's Avatar
srercrcr
When I do this with my F150 I don't fool with a drill, I just idle the engine.....pouring new fluid in the top while the old drains out.
Old Apr 19, 2006 | 08:32 AM
ajguzik's Avatar
ajguzik
Are you using Mercon ATF, or another fluid for power steering?
Old Apr 19, 2006 | 04:03 PM
aquanaut20's Avatar
aquanaut20
Any ATF will work, I used mercon V, because it was handy and it is a synthetic so it takes the heat better
MJScore
Jan 21, 2015 05:34 AM
mr. grieves
Jun 10, 2014 05:27 PM
waskin27
General Automotive Discussion
Jun 30, 2013 11:21 PM
crazer42
May 15, 2009 09:01 PM
otto
Feb 1, 2001 09:33 AM
