Cabs
Old Feb 15, 2014 | 05:52 PM
YooperUno's Avatar
YooperUno
Cabs
I have a chance to get a regular cab for a 1977 that came off a 2wd want to put it on a 4wd read somewhere on here u have to raise the cab because of the tunnel is different or smaller than a 4wd been trying to find that post and cant is someone out there know of anything about this. I even did the search ?
Thanks
Old Feb 15, 2014 | 05:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Not a big deal.
If the replacement cab has a low rise trans tunnel (no removable tunnel cover) just cut it out and use your old one.
Old Feb 15, 2014 | 05:59 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Measure carefully and cut away, the tunnel is stamped already so you can see where to cut.
Look at the picture, be sure to cut well inside the line or the hole will be too big.
The little depressions for the blind nuts to fit in are already there.
Old Feb 15, 2014 | 06:03 PM
YooperUno's Avatar
YooperUno
ok thanks folks had to cut that out anyway because I have a 4 sp tranny so that is the only difference then Thanks again
Arbiter
13
Feb 9, 2017 11:13 PM
Tsoptich
Jan 2, 2011 03:49 PM
351beast
Nov 27, 2007 11:12 AM
Umpqua Arms
Mar 6, 2003 12:36 AM
351coupe
Nov 8, 2002 12:15 PM
