transfer case leaking?
Old Feb 15, 2014 | 04:39 PM
anthrax91's Avatar
anthrax91
A few weeks ago I started hearing a rattling noise. I found out I accidentally had the truck still in 4h and drove around like that for a couple weeks. I shifted it into 2h and the rattling stopped. Now a few weeks later I started to hear it again but this time I crawled underneath and found this.
I don't know much about trucks but it seems to me that the transfer case is leaking. Could it be a seal or something more serious? I'm also unsure of the rattling noise. The rattle happens when I'm accelerating, decelerating and even coasting.
Old Feb 15, 2014 | 05:49 PM
gatorfor88's Avatar
gatorfor88
Looks to be front output shaft seal leaking. As far as the rattling are you sure it is still not locked in?
Old Feb 15, 2014 | 06:02 PM
anthrax91's Avatar
anthrax91
Is this something I need to immediately get fixed or can I put it off? And yes, I have the hubs free and it shifted into 2H.
Old Feb 16, 2014 | 01:14 AM
tbear853's Avatar
tbear853
When it was in 4Hi all that time, were the hubs locked or free when you discovered it?
At minuimum, I'ld check level by pulling fill plug and using something to dip, like little finger if it'll fit ..... or a bent stick if not. Proper fill is bottom edge of fill plug (higher than drain plug).
My NP205 also could use a seal and gasket R&R as well as front and rear C-6 transmission seals. Likely when I R&R engine. Meantime, I will keep an eye on levels.
Old Feb 16, 2014 | 02:53 PM
anthrax91's Avatar
anthrax91
The hubs were free but it was making the rattling noise and when I shifted the truck back into 2h where it should have been the noise stopped.
emd014
Aug 27, 2018 06:51 PM
Melansk
Jun 15, 2017 06:50 PM
JKessler00
Oct 3, 2012 06:51 AM
68bluebeast
Apr 25, 2011 04:42 PM
Big-old-460
Mar 9, 2011 06:11 PM
