Standpipe and dummy plugs question
Old Feb 14, 2014 | 06:11 PM
scarty111's Avatar
scarty111
I'm having my oil cooler and egr cooler replaced,what do I need to know about how many dummy plugs I need and I'm assuming I need one stand pipe?
Old Feb 14, 2014 | 06:19 PM
rob40cal's Avatar
rob40cal
One stand pipe and dummy plug per side
Old Feb 14, 2014 | 07:02 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Focus more on updating the STC fitting than the Dummy Plugs.
Josh
Old Feb 14, 2014 | 07:17 PM
scarty111's Avatar
scarty111
Josh
What is that and how many do I need?
Old Feb 14, 2014 | 07:23 PM
Bullitt390's Avatar
Bullitt390
The STC fitting attaches to the HPOP and directs the high pressure oil to the branch tube.
It's known to blow and leak on 05+ engines. With everything torn down for EGR/Oil coolers it makes perfect sense to spend the $60 or so and update it at that time.
With digital gauges it is fairly easy to see when the Dummy Plugs are failing, and sense they aren't very difficult to replace it isn't a must do it now item as the STC is.
Josh
Old Feb 14, 2014 | 07:28 PM
scarty111's Avatar
scarty111
Josh
Thank you,any more tips would be appreciated. Im new to this 6.0 stuff.
Old Feb 14, 2014 | 11:15 PM
9228.bobcat's Avatar
9228.bobcat
What kind of coolant are you going to put back in it?
Old Feb 15, 2014 | 07:35 AM
scarty111's Avatar
scarty111
I've already had my cooling system flushed out a couple of weeks ago and replaced the coolant with EC-1 and installed a XDP coolant filter .
Old Feb 15, 2014 | 08:16 AM
xaviar's Avatar
xaviar
Good to hear you've already flushed your cooling system already.
Old Feb 15, 2014 | 08:21 AM
scarty111's Avatar
scarty111
Already done, doing both coolers in about a month.
xaviar's Avatar
xaviar
Delete post
Old Feb 15, 2014 | 11:11 AM
Fal-308-Win's Avatar
Fal-308-Win
Josh
This is the best advice given
sent by a message tied to an arrow using a Long Bow
KINGDAR
Jan 5, 2020 06:21 PM
bass-n-fire
Dec 29, 2016 02:37 PM
flcracker9
Oct 29, 2014 03:54 PM
JonArmy
Mar 16, 2012 02:48 AM
68murc
Mar 27, 2007 07:04 PM
