Thoughts on coolant caps
Old Feb 14, 2014 | 09:08 AM
Iaff113's Avatar
Iaff113
How Often do most of you change your resivor coolant caps. I have been doing mine twice a year. Also do you replace with OEM or stant caps.
Old Feb 14, 2014 | 09:23 AM
loubell's Avatar
loubell
twice a year?
I ran the original cap and bottle for 8 years/150K miles.
The bottle developed a small crack in the back of it, so 2 years ago I bought a Dorman bottle w/cap from Rockauto. Still going strong.
Old Feb 14, 2014 | 09:53 AM
mhoefer's Avatar
mhoefer
Still on original on a 2005. But this truck has Been on the low mark since shortly after purchase, when they put on the new sticker. Partial coolant flush at 50k miles, full flush at 100k, coolant filter since 2007.
Old Feb 14, 2014 | 10:07 AM
Iaff113's Avatar
Iaff113
The only reason I change it is because it's cheap and wasn't sure the life on the springs I don't have a pressure tester so I don't know
Old Feb 14, 2014 | 10:25 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Once at the 60k coolant flush, just cause I felt like it. Shouldn't need to unless it fails and you get a whistle from it
Old Feb 14, 2014 | 10:39 AM
Fal-308-Win's Avatar
Fal-308-Win
200k on original cap. My dedicated pressure gauge still shows 8/10 psi while running.
Old Feb 15, 2014 | 11:56 AM
Texas Bob's Avatar
Texas Bob
I took my OEM cap to O'Reilly's and they tested it and it could only hold 12 PSI and the spec is 16 PSI. I replaced it with a Stant because that's what I have been using for 50 years on everything I own. O'Reilly's did not carry Stant so I went to NAPA and picked one up. This was at 83K about a year ago.
Some have said that 12 PSI is OK. But it does appear that you may be burning money for something that does not require replacement very often. If you are unsure, have it tested.
bla1879
Jul 9, 2017 08:56 PM
oxt127
May 22, 2015 12:52 PM
StanleyZ
6.4L Power Stroke Diesel
51
Oct 26, 2014 09:30 PM
darren32
6.7L Power Stroke Diesel
17
Dec 10, 2011 03:34 AM
WWBeast
Sep 14, 2011 09:32 AM
